How strong is a 12 bolt
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazingboy, Apr 30, 2003.
  1. blazingboy
    blazingboy 1/2 ton status
    Dec 2, 2001
    120
    Georgia
    Well guys the 10 bolt finally went boom with the 33 inch tsls now I can't decide to go with a 14 bolt or a 12 I think that 14 would be over kill. I don't do heavy wheeling just some trails and some mud and a heavy foot on pavement. So will a 12 be strong enough and also will it bolt right in. Also did they come with 3.73's stock.
  2. JHG
    JHG 1/2 ton status
    Jul 28, 2002
    129
    Iceland
    I know that the 14 bolt is stronger, and if I would be changing I would choose the 14 bolt. I have heard a storys for years that I should not use anything bigger than 35" with 12 bolt, so I figured I would use my 12 bolt (and dana 44) until it would brake down....
    But....I have been using the same 12 bolt under my 1981 K5, with 38" tires, 4.88, lockers, and healthy 350 cid for many years. It was there when I bought the truck 7 years ago and had been there for at least 7 years before that (it might have been with it from the factory). It has only once left me stranded.
    That was because a shop forgot to put a oil into the housing after it had drained all the oil of it. I drove it for 3 months with no oil /forums/images/graemlins/shocked.gif until it broke down.
    I could proof my case and the insurance company of the shop did pay for the damage /forums/images/graemlins/deal.gif so now everything inside it is new
    I used my truck as a daily driver and use it a lot for wheeling. Now I only use it to wheel /forums/images/graemlins/cool.gif
    So I think 12 bolt should be strong enough...but it is much cooler to have the 14 bolt /forums/images/graemlins/wink.gif
    Jon H. Gudjonsson
  3. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    My K-5 had a 12 bolt with 35's in it from 77 till last year when I went to one ton and 38's. The 12 was the factory 12 from 74, for the last five years had a detroit in it, and for the last 2 a doubler without breaking it. With 33's it should last as long as the truck.
  4. rawhead
    rawhead Registered Member
    Dec 6, 2002
    52
    So. California
    My '79 has a factory 12 bolt and it's plenty strong. I run 35's. I have changed the axle shafts out for some chromoly ones just for peace of mind. Superior Axle offers the whole rear kit (2 shafts, lug nut studs, bearings and seals) for $299. It's a good option if you don't want to go to heavy 1 Ton items.
  5. Chris_T
    Chris_T 1/2 ton status
    Mar 17, 2001
    718
    Saskatoon, SK
    And yes, some came 3.73 stock
  6. BlazinRojo
    BlazinRojo 1/2 ton status
    Mar 29, 2001
    111
    San Luis Obisbo, CA
    Does a 12 bolt bolt right up and does it have the same lug pattern as a 10 bolt (6 on 5 1/2 I think)?
  7. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    I did the swap and the only thing different was the e-brake and the yoke. I switched the brakes to solve that problem and had a different yoke welded on the drive line when I had it lengthened. I could have just replaced the yoke on the rear if I was thinking.
  8. COCHEV
    COCHEV 1/2 ton status
    Jul 9, 2002
    4,055
    Washougal WA
    did you have the full carrier detroit or a drop in locker?
  9. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    What's the difference with the e-brakes? /forums/images/graemlins/confused.gif
  10. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    It all depends on the wheeling you do. It sounds like a 12 bolt will work for you, based on the wheeling you described.
    For me on the other hand, I've already broken my 12 bolt once, spent too much fixing it, and am now prepping 3/4 ton axles to swap in. I wheel on trails and in the mud with my heavy Burb on 32's. /forums/images/graemlins/thumb.gif
  11. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I ran one with 38's for years and blew it only once. I think you would be fine.
  12. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    I just did this and it bolts right up, all you need is conversion u-joint between the driveshaft and the 12 bolt. It's about 19.95 in autozone and I think the part number is 1330.
  13. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    make that conversion joint... 3-3130 at autozone
    Blake
  14. bee32
    bee32 1/2 ton status
    Aug 6, 2001
    401
    Virginia Beach Va.
    Does this apply to all 12 bolts? I am about to do this myself. They have one at my local autozone for 14.99.Thanks!
  15. blazingboy
    Dec 2, 2001
    120
    Georgia
    Ok guys I think I will just go with the 12 bolt I believe it will do all I need to do. Now I just got to find one.
