How strong is a SM465?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by kickinasphalt383, Mar 4, 2002.
  1. kickinasphalt383
    kickinasphalt383 1/2 ton status
    Dec 6, 2001
    224
    Michigan
    I know they are really strong, but how strong?
    Is it stronger than a NV4500? How much power can one handle?
  2. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    Sm465's are stronger than stone! You can grind em' into gear, jam em' into gear, baby them some, and just all out tear them up and they will still work fine. Mine was O.E.M. on my 84 and through 5 owners and to the day has never been rebuilt. Its gone from Wyoming - TX - FL - to Louisiana (me). I really prefer the SM for ease on drivetrain. I can baby my axles or I can slam them. The common caveman or mechanical clutch on them can be a pain in the knee at times.
    I don't have acess to nor have I driven a NV4500 but one day I hope to slap one in place of my sm465. I will be keeping the SM because I think it will work forever. From what I hear though the NV's are about as strong. However, I believe the gears in the SM465 are a bit thicker and therefor a stronger tranny internals wise. I'd love the OD one day though. If you can't afford a NV the sm465 is by far nothing to spit at many people here can vouch for dogging there's as well with little back talk from the tranny.
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I've never seen one fail. I've got one in the garage that is going in my truck when I put it back together.
  4. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>The only broken one I've heard of was mine, and thats because it was full of mud for a few months and I didnt know it
  5. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    Yes, they are stronger than an NV 4500.
    It is really a 1 ton to 1.5 ton transmission. They can hanlde the torque of a big block with no problems.
    Only problem is a tendency to fall out of 2nd gear when they get worn, but as long as you stay on the gas, it will stay in.
  6. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    dodge guys dont like the nv4500, cant remember what it was that breaks, 5 th gear comes apart or something?
  7. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,131
    27
    El Paso, TEXAS
    I thought it was 3rd or last gear that it fell out of. and there is an easy fix for that too.
  8. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    the one i drove popped out of 2nd gear, but it was when you WERE on the gas....
    mike
  9. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    are you guys sure you aren't talking about the same gear? Its common for some (not pointing any fingers here ....:) to say the SM465 has an L gear, 1,2,3. I just call it gears 1-4, and I start in second usually. My tranny has popped out of third (1.7 to 1 ratio gear) in some real nasty stuff. Now its just automatic for me to hold the shifter from bouncing around when driving hard.
  10. ArrowheadK5
    ArrowheadK5 1/2 ton status
    Aug 3, 2001
    252
    Northern MN
    I think the stock transmission on my k20 is a SM465? It pops out of 2nd gear (L-1-2-3) when at low RPM and if I try I can force it out of 3rd gear at low rpm. It does not have any effect on my driving, so I don't consider it a problem.
  11. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    The 465 should survive with no problem even in a built big block application.
    I would guess input max to be in the 800 hp range.
    They do like to fall out of second gear when the synchros are worn, and I think they about come from the factory with the synchros worn, so who cares.
    BTW, if you look at a stock SM465 shifter, it is labeled L 1 2 3 not 1 2 3 4.
    -- Mike
  12. kickinasphalt383
    Dec 6, 2001
    224
    Michigan
    i was thinking of swapping a cummins into my truck(so loads of torque). but if a NV4500 can hold the cummins then a SM465 should no problem... i also hope they make a super strong clutch kit for it to!!
  13. RedDwarf
    May 9, 2001
    816
    Exactly. I always use the L-1-2-3 designations. "Granny Gear" isn't used for regular driving. Makes sense to me to start off in "first" instead of always using "second".
  14. RedDwarf
    May 9, 2001
    816
    BTW, 2nd gear is 1.57 in the 465, not 1.7
    It was 1.7 in the SM 420
  15. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    The shift knob on my '72 465 is labeled 1,2,3,4, as god intended. They just went to that L,1,2,3, labeling when less intelligent people couldn't figure out that you have to start in second gear.
  16. thatK30guy
    Jan 12, 2001
    32,076
    55
    I have always gone by the 1-2-3-4 pattern.
    I have also experienced the '3' gear popping out of gear while accelerating. Got that repaired easily, too.
  17. tRustyK5
    Jul 23, 2000
    36,188
    1,396
    E-town baby!
    I've seen both ratio's claimed for SM 465's...if I'm not mistaken MJ did a tooth count to confirm and found it to be 1.7:1
    Rene
  18. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    I believe 2nd to be 1.57, not 1.7.
    Hmm, I didn't know the early 465s were labeled 1 - 4, not L - 3.
    When I got my truck, it had a crappy 8-ball shifter knob that I chunked as soon as I found an original 465 knob. But mine is the L - 3 style.
    Do you know of any source for a 1 - 2 - 3 - 4 knob? I've never seen one and kinda like the idea of that one.
    -- Mike
  19. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    The '70 Chevy C-10 I owned at one time had the 465 with the 1-4 shift pattern knob. I had to replace that transmission with another used 465 after it crapped out, and it also had the 1-4 shift knob. I'm not sure what year that tranny was.
    My '86 has the L-3 shift knob.
  20. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    input gear is 17 teeth it drives a 40 tooth counter gear
    3rd- 36 tooth counter drives 26 tooth speed
    2nd- 23 tooth counter drives 35 tooth speed
    1st- 14 tooth counter drives 39 tooth speed
    1st = 6.554
    2nd = 3.5805
    3rd = 1.699
    4th = 1
