How strong is the 14 bolt SF?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by shum1, Feb 28, 2001.
  1. shum1
    shum1 1/2 ton status
    Oct 8, 2000
    270
    UTAH
    I was thinking of getting the FF but the SF seems like an easier swap in my 1990 suburban. Are there any aftermarket positractions for this c clip axle? Thanks.
  2. bigerik
    bigerik 1/2 ton status
    Feb 24, 2001
    184
    Sonoma County, CA
    The 14 bolt SF has a 9.5" ring gear, and the 14 bolt FF has a 10.5" ring gear. The FF can stand up to more abuse than the SF, but the FF is, as you know, heavier and hangs a little lower. Get the FF(w/ a Detroit Locker) and live with the 8 lug ramifications; if you opt for the SF, you will want to step up to a FF later, and all the money put into the SF will be wasted. Even if you have to have 8 lugs in the rear and 6 in the front while you're saving for your new front end, you'll be glad in the end.
  3. jerseyk5
    jerseyk5 Registered Member
    Jan 26, 2001
    42
    NJ
    I just did the 14 sf swap and so far I found one from arb, auburn hi-pro series, and one from power trax. Not sure myself how good any of them are?
  4. shum1
    Oct 8, 2000
    270
    UTAH
    This vehicle is to be used primarily for towing. I'm having a hard time trying to find just the SF brake backing plates from a 1983 or newer that are needed to swap the FF into my car. Does the SF come in 6 lug? That would be a bonus. If so what year?
  5. jerseyk5
    Jan 26, 2001
    42
    NJ
    Yes, the 14sf comes in 6 lugs. Mine came out of a 95 C2500(3/4 ton) 2wd pick up. I had the perchs moved in and I had the double shock mount I had on my 10blt rear welded on. After that it bolts right up. I believe you want to look for one out of a 88-96 3/4 ton. You will need the conversion u-joint napa#447 and new emergency brake cables. The part numbers for the brake cables are also a napa part #s and are 93254 and 93898. I got my rear from truckparts.com. for 500.00. It was complete drum to drum and in really good shape. They had 3 or 4 more out there last time I looked.
  6. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I'm going to find one from an 82-87 3/4 ton and use 6 lud axleshafts and drums. The spline count is the same so they will swap in. That way I don't have to move the perchs and shock mounts.
    90K5
  7. shum1
    Oct 8, 2000
    270
    UTAH
    Good Idea 90k5, where do you look for just the shafts and drums? The junkyards I go to dont seem to want to sell axle parts only complete housings w/ axles. What size are the drums you plan on using?
  8. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Whatever I can find. if you can go to a pick and pull or something, you may be able to swap out the axleshafts and drums before you buy the axle, then you wouldn't have to buy a complete axle plus other parts.
    90K5
  9. AJMBLAZER
    AJMBLAZER Better to be lucky than good. Premium Member
    May 18, 2000
    22,793
    101
    Paducah, KY
    Last time I was on Tractech's website, they were listing a Detroit Locker for the 14SF as a new item.
    1992 Blazer Sport, 350 TBI, 4L60, 3" Flowmaster, K&N, 3" Rancho, 285/75R16 on 16x8 Baja's[​IMG]
