How tall are 36x12.5 Swampers?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by AJMBLAZER, Apr 12, 2002.
  1. AJMBLAZER
    AJMBLAZER Better to be lucky than good. Premium Member
    May 18, 2000
    22,792
    100
    Paducah, KY
    How tall are the various 36X12.5 TSL, TSL Radial, and TSL SX's when actually mounted on a 10" wide rim?
    I know Interco is famous for "over estimating" the actual tire height./forums/images/icons/tongue.gif
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I have never heard about Interco "over estimating" on their tire size. I have heard that they are the closest to the "Nominal" size of any manufacturer. My 36x12.5 15 TSL's were just the size they were stated on www.Intercotire.com. 35.75x13.5...smaller in diameter by .25" (very little IMO) and actually wider than stated on the sidewall by 1".
  3. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>My Radials are just over 36"
  4. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
  5. AJMBLAZER
    May 18, 2000
    22,792
    100
    Paducah, KY
    Hmmmmm............sounds good guys. I've heard from people that their Swampers were a noticeable amount shorter than advertised. Buddy of mine just got some 38/13/16 TSL's and mounted on a 16x8 they actually measure like 37.1" and 11.5". Guess the 36's aren't like that. Now I just have to decide on what flavor 36x12.5R16.5 I want./forums/images/icons/cool.gif
    Anybody else?
  6. BigTex
    BigTex 1/2 ton status
    Dec 27, 2000
    974
    South Texas
    My swamper radials actually seem like a very tall 36". I haven't actually measured them (I'm at work), but keep in mind that vehicle weight and tire pressure also have alot to do with mounted tire height.
  7. tacoma972
    tacoma972 1/2 ton status
    Jan 6, 2002
    114
    West Point, Ga.
    if mounted on 16x10 inchers it probably will increase the hight because of the bubble effect
  8. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    I'd lilke to know too.
    As meny members as we have here, I'm a bit shocked that we don't have a "list" of some-sort, as this question, or something like it, gets asked often. (I asked the same question a mounth or so-ago, and had some great in-put, but would like to see more!)
    <a target="_blank" href=http://coloradok5.com/forums/showflat.php?Cat=&amp;Board=blazer4x4&amp;Number=350466&amp;page=&amp;view=&amp;sb=&amp;o=&amp;vc=1>http://coloradok5.com/forums/showflat.php?Cat=&amp;Board=blazer4x4&amp;Number=350466&amp;page=&amp;view=&amp;sb=&amp;o=&amp;vc=1</a>
  9. AJMBLAZER
    May 18, 2000
    22,792
    100
    Paducah, KY
    Tacoma, the wider the rim the shorter the tire will be. Take an inflated balloon and squeeze it. The ends not covered by your hand expand outwards. Works the same way with tires and rims. Not talking any big difference here. No more than a 1/4" or so between a 16x8 or 16x10.
