How tall can I go without changing drivelines?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ellero, May 10, 2004.
  1. ellero
    ellero Registered Member
    Jan 25, 2004
    66
    Covington, Georgia
    I have an 84 K5 blazer and and still stock sitting on worn down 33s. I want to go with a 6 inch lift and 35s, but am concerned that I might have to change my drivelines. I plan to change out to 3/4 or 1 ton axles in the future when the money is there, but it will be a while. My goal is to clear 35s with maximum flex. I drive this truck hard and it does see quite a bit of air time in the desert. It also spemds a lot of time in the sand and mud. I just dont want to have to make a MOD only to have to do it over again. Please help me with any advice. I want to do it right the first time, but money is tight and I have to do it in stages. If anyone has built a truck well over time while still using it between MODs, your info would be greatfull. Thanks. John /forums/images/graemlins/k5.gif
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I've seen members running small lifts and large tires by trimming fenders. When I went 6" lift, I had to have new driveshafts made, no biggie in my opinion.
  3. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    If you jump your truck you want to keep a low center of gravity by lifting it the minimum amount nessisary. I think you can reach your goal with 2.5-4" lift, 35" tires and some fender trimming. Not only would you need to modify your drivelines for 6" lift but there are also longer shocks, steering correction, extended brake lines, etc. The more you lift it the more mods are req'd to correct the changes.
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    If you want air under your truck in the desert, you should brace the front diff so the tubes don't break off the center section. See the april Four Wheeler for a cool oops pic /forums/images/graemlins/k5.gif
  5. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    I am running 6" roughly with 38.5x14.5 swampers, I relocated the axles 1.5" forward and back added some 4* shims and I have no problem at all, I had to trim the sheetmetal, but 35's should fit fine
  6. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    My yellow K5 in my webshots has BFG 35's with a 2.5" lift and trimmed fenders. I don't run any sway bar and I don't have any problem with rubbing(check the album that says Tecate flex). It is very comfortable and stable to drive.
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    If you want 35s with maximum flex, use the softest 2.5" springs you can find and start hacking.
  8. skratch
    skratch 1/2 ton status
    Oct 28, 2003
    1,646
    Gorveport, OH
    I totally concur.
    I started cutting my fenders this week and I only have 2.5" springs, I could easily fit 35's now.
  9. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    If your 84' is rust free than don't cut the fenders....keep it in good shape especially if you plan on reselling it one day. Most of the people that would be interested would look at the fenders and say "What the heck did you do to it?" You would be lucky to find someone that didn't mind.
    Get the 6" with 35's and see if your drivelines will work...mine did when it was still a 1/2 ton for a long time.
  10. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    mine is headed for 4" lift and 44's can you say /forums/images/graemlins/hack.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/grind.gif /forums/images/graemlins/grind.gif /forums/images/graemlins/grind.gif
  11. bottomfeeder
    bottomfeeder 1/2 ton status
    Mar 9, 2004
    277
    Oklahoma City
    6" Lift with 35's
    Along with the lift came a new drag link, sway bar kit, longer brake lines, longer shocks, and e-brake kit.
    Big tires come when I get some beefier axles.
  12. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    I have 9" of lift with no fender trimming and smashed my fender with a 36 - 12.50 / 16.5 Swamper SX /forums/images/graemlins/angryfire.gif
  13. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    he already said he wheels the truck. posing is not an option here. lower CG is the way to go for sure. soft springs and fender trimming sounds to be your best bet.
  14. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    [/ QUOTE ]Nobody said anything about him driving only on the street, he can wheel it plenty without destroying the fenders and still get a good fair for it if he decides to ever resale it. /forums/images/graemlins/smirk.gif
    Plus there isn't much for hills in the desert. /forums/images/graemlins/rolleyes.gif
  15. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Desert is all about high speed. Soft suspension with good shocks and lower COG is still the answer.
    There isn't much of anything except mud bogging where increased height is of much advantage, and even that is questionable in most cases.
  16. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    4" lift only requires minimal cutting to fit 35" tires.... /forums/images/graemlins/peace.gif
