How tall is your steering arm (60)
Discussion in 'The Garage' started by MTBLAZER89, Jun 5, 2006.
  1. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    This pawned from garlicbreath's 52's and crossover arm thread. Here is what we need, and this should be a good one for everybody to refer to since "which 60 arm" is a pretty common post.
    1. What arm are you running?
    2. How tall is the arm?
    3. Your suspension setup. Pack thickness would be useful info too. Zero rates?
    4. Any clearance issues? If so tie rod or drag link? Diameter of tube?
    5. Your opinion of arm. Overall quality fit service etc.
    Any pics would be good especially any side by side of different arms.
    Ok GO:D
  2. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    1. What arm are you running? Shakerbuilt
    2. How tall is the arm? 1" thick
    6 leaf pack 56s, with overload
    1/2" of clearance from drag link (1.25") to spring pack with the wheels straight. Hits at full lock.
    Arm works, just not really nice to look at. I would have really like to had an arm with an intergrated kingpin cup.
  3. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    Cool, now lets see how much info we get and if a mod can make it a sticky.
  4. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    WFO double.
    About an inch.
    52s, 5 leaves in the pack, no zero rates.
    no. My tie rod and drag link are 1.5" I believe...
    great arm, good people at WFO.
    here is a pic... pretty much the worst pic ever of a steering arm... but then again thats not what I was trying to capture in the pic either!
    j
  5. MTBLAZER89
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    Thanks J thats exactly what I was lookin for. Now we need all the other brands and setups:D
  6. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    NWF Single Crossover arm
    Total height is around 2". Minor thickness is 1" (see the pic for explanation)
    Not sure on the brand of leaf springs but they are stock length, and around 6" lift. Pack thickness directly below the drag link is 1.75"
    No Zero rates as of yet but they would fit without issues.
    Not even close to having clearance issues with the NWF arm.
    Tie rod and Draglink are both 1.5" DOM.
    Top quality, perfect fit.
    Now for a few measurements to add a little detail. All measurements were taken in a verticle distance just outboard of the pass side leaf spring.
    Bottom of Tie rod to the top of the Draglink = 6.5" or a little more
    Ground to bottom of leaf spring(directly below draglink, next to leaf) = 19.5"
    Ground to top of leaf spring(directly below draglink, next to leaf) = 21.25"
    Ground to bottom of Draglink(directly below draglink, next to leaf) = 19.5"
    Distance between top of leaf pack and bottom of Draglink = 2.75"
  7. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I really like the "natural" steel look you have on that arm:D
    Ira
  8. readymix
    May 30, 2004
    6,706
    26
    Invisable paint:D
  9. MTBLAZER89
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    Oustanding Chief:D
  10. hack500
    hack500 1/2 ton status
    Sep 16, 2005
    523
    Templeton, Ma
    from Poison Spyder
    1"
    4" lift springs
    nope
    beefy - well machined.
  11. MTBLAZER89
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    I know somebody around here has Sky and ORD arms. Post up guys:laugh:
  12. sandawgk5
    Oct 28, 2003
    6,881
    Arm=ORD
    Thickness=1.25"
    Suspension= 4" spring pack is 1 7/8" thick.
    Clearance= bottom of ORD draglink to spring pack is 2"
    arm to sidewall of 37X12.5 on 15X8 with 4.25 backspacing is 2"
    Overall=Well made arm weighs almost 10#, also drilled for Dedenbear Knuckles, Would prefer they offered in rear histeer but otherwise an excellent arm.
    This is the only picture I have but it is taken at full lock:D
    Ira
  13. MTBLAZER89
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    Cool Sky or any of the same arms with different suspensions?
  14. MTBLAZER89
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
