How the heck do you get the steering arm off?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by PetaKane, May 10, 2002.
  1. PetaKane
    PetaKane 1/2 ton status
    Apr 17, 2002
    530
    Oklahoma City OK
    I've used every hammer I own. If only I had access to a torch. How do you get it off?
  2. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Keep beating.
  3. bigblue
    bigblue 1/2 ton status
    Dec 6, 2000
    658
    southern california
    Just keep beating the hell out of it...
  4. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    I bought a 4 lb sledge and smacked it a couple times. When it loosens you'll have to put a small screwdriver in the tapered cone locks and spin them out. That's how I got 'em off. Also, a lot of wd-40 or the like doesn't hurt. I beat it side to side and top/bottom to loosen it up as much as possible. Those taper locks make it a pain in the arse to take off. Mine had been on since 1974, so it was good and stuck.
  5. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    If it ain't too late, loosen the 3 nuts and drive around the block, the movement will help free it up. PB blaster or wd-40 will help alot too. I used everything on mine, hammers, pullers, 6 foot pry bar and a torch. After alot of swearing I got it off, then my uncle stopped by and gave me that idea to try...would of saved me a bunch of time and energy,LOL.
    He said thats the way they did them at the dealer.
    On my other axle all I did was remove the springs and rolled the axle over and gave it a hit with a hammer and it fell off.LOL
  6. Tuff84blaze
    Tuff84blaze 1/2 ton status
    May 12, 2000
    119
    Liberty Lake, Washington
    Turn your wheel to the right so that you can get a good angle at hitting it, and just keep putting penatrating oil on it and smacking it.
  7. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    OTC makes a set of cone pliers that will make that job a peice of cake.
    Once the cones are off the arm will slip right off.
    I do not soak the studs or any of that stuff, I just remove the nuts and with a 6lb hammer I whack one end of the arm upwqards and then reseat it the cone will pop up a little and the pliers will pluck it right out.
    Then I go to the opposite side and repeat.
    Once the 2 end ones are off the middle one will be loose enough to be plucked out also.
    it has not taken me more than 10 minutes to remove a steering arm.
    <a target="_blank" href=http://www.cartools.com/Merchant2/merchant.mv?Screen=PROD&amp;Store_Code=001&amp;Product_Code=hvsdOTC7077&amp;Category_Code=SD>cone pliers</a>
  8. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    Put the nuts on the bolts and thread them till thier flush with the end of the bolt, and lightly hit them on thier end, this will kinda break the torqe still holding.. then HIT the extending end of the steering arm down and upwards, this will POP the taper loose... if this dont work, go lift weights /forums/images/icons/smile.gif
  9. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    I have the OTC cone pleirs for tapered cones on big rig rear axles they help alot.
  10. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    I think I must have gotten lucky when I recently changed my steering arm, after I removed the nuts I checked to see how long it would take me THIS time to get the steering arm off, what do you know, 13 seconds. I could not believe what had just happened. Some GOD must have come down from upstairs and helped me a bunch THIS time. I used WD40 and a 5 lb. sledge hammer with 3 hits.
  11. wahbob
    wahbob Registered Member
    Dec 27, 2001
    76
    Austin,Texas
    Cursing alot really helps!
