How thick are axle tubes on a 14bff??
Discussion in 'The Garage' started by 85mudblazin, Aug 14, 2004.
  1. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    what the title says.
    -Chris
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    From the 14 Bolt Bible... /forums/images/graemlins/thumb.gif
    1/2 Inch Thick walls
  3. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    1/2" [darn] thats thick
  4. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    I have some cut off 14FF tubes in the garage and they are .375" thick (3/8").
  5. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    The ones I cut are 3/8" as well. Axle was a '79 3/4-ton.
    I've heard some of the later 14FFs with the finned housing may have thicker tubes in some applications.
    They also appear thicker if you see one sheared off at the spindle. Then you're seeing the combined thickness of the spindle stub & tube.
  6. bluejeep
    bluejeep 1/2 ton status
    Jan 9, 2004
    106
    Des Moines, IA
    .375 For all the ones I've cut too.
