How tight are new ball joints....???
Discussion in 'The Garage' started by ColAdo82K5, Feb 28, 2004.
  1. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    Ok everyone,
    I just put new ball joints into the flattops, and am putting them on to a 44 housing. I did the torque sequence, 80 on the lower, 50 on the sleeve, 100 on the upper nut. These knuckles are sort of hard to turn ! I've never done this style of ball joints before, so i'm not sure exactly how much "ummfhh" it takes to turn them, while the axle is just sitting on jackstands. I'm thinking one of three things....
    1. Hey numbskull...you over tightened something !
    2. A few thousands pounds of truck would turn that easily !
    3. How stiff would this feel if it had a steering box attached to it...?(hard to do with the axle in the garage and the truck outside)
    Did any one else have these ideas when doing balljoints ?
    Blake
  2. avgas
    avgas 1/2 ton status
    Jun 5, 2003
    179
    Renton, WA
    mine were surprisingely tight when a replaced them about a month ago, but everything functions as it should. with the tirrod connected it was pretty damn hard to turn the whole assembley.
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    new ones are tight as hell
  4. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    They should be almost too tight to turn your first try. Not so tight you can't move 'em though. I was worried about mine the first time too. Greese them up real good and enjoy less steering wheel play when you get the axle in.
  5. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Mine were pretty damn tight 'till I torqued them to the proper torque then they were real smooth to turn with not too much effort. The tighter the adjuster sleeve is-the easier they turn. /forums/images/graemlins/crazy.gif
  6. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    i dont have my manual in front of me, but there is a spec for the amount of effort it takes to turn the knuckle
  7. 78k20
    78k20 Registered Member
    Feb 28, 2004
    53
    Eastern Washington
    According to spec, at a right angle pull with a fish-scale, should not exceed 25 lbs. for each knuckle in either direction-after initial breakaway that is.
    Hope that helps
    Mike
