How to 6" lift in rear?
Discussion in 'The Garage' started by JUNIOR-K5, Mar 28, 2006.
  1. JUNIOR-K5
    JUNIOR-K5 1/2 ton status
    Dec 20, 2005
    387
    SO.CAL
    Can anybody help me find a way to get 6" lift in rear without changing springs.I plan on putting 6" tuffcountry hd in front dyi with 6" shackles and zero rate in rear.Will that give me 6" in rear or do I really have to buy 2" springs.:confused:
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I think you will be short. What you described in the rear is what I have and it sits level with my 4" front. But I also have super soft 56s in the rear. I would suggest going with the flip and a set of 2" 56s the length will help soften them and they will flex like mad:D
    Ira
  3. protechk5
    protechk5 1/2 ton status
    Sep 26, 2004
    2,015
    VA
    Never seen a 6inch shackle in the rear, but Im sure it can and has been done. If you really dont want to change out springs, run a 4inch shackle, with 1inch zero rate and maybe a 1inch add a leaf. Or maybe a 4inch shackle and a 2inch block??
  4. sandawgk5
    Oct 28, 2003
    6,881
    Here is my shackle angle with the DIY flip and a 6" shackle.
    Ira
  5. JUNIOR-K5
    Dec 20, 2005
    387
    SO.CAL
    Just talked to a buddy and he has a brand new set of 56 rear 4" tuffcountry springs and said he would give me a good price.Now my question is can I install them with diy4x shackle flip with 6" shackles without any problems.Will that give me a full 8" I only wanted 6" but cant pass the deal on the springs.Thank SandawgK5 for the pix.
  6. Masiony
    Masiony 1/2 ton status
    Sep 2, 2005
    729
    Springfield, OR
    you should be golden, it should add up to 8". and DIY4x, is hands down the best shcakle flip kit out there. he does two things that the others dont. 1. he converts it to a simple 2 piece side shackle. 2. he includes the brackets with nuts welded to them for the inside of the frame. not so critical on a pickup, but on a blazer the gas tank is in the way and this is a life saver.
