how to adjust castle nuts of 10 bolt?
Discussion in 'The Garage' started by Cornfield creations, Oct 4, 2006.
  1. Cornfield creations
    Cornfield creations 1/2 ton status
    Oct 19, 2005
    1,283
    Jasper, Indiana
    Just what the title says. I put the ball joints in already but could easily be loosened up again. I got the castle nuts close to where the original ones were. I used GM ball joints.
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    did you torgue the nuts down to the correct torque spec? You might have to adjust the sleves that are in the axles inner c its self
  3. Cornfield creations
    Oct 19, 2005
    1,283
    Jasper, Indiana
    what do you mean the sleeves in the inner c?
  4. JeremyK5
    JeremyK5 1/2 ton status Premium Member
    Aug 12, 2001
    549
    Indiana
    He's talking about the sleeves used to adjust the preload on your balljoints. they are beneath the castle nuts on the top balljoints. They look like this-
  5. Cornfield creations
    Oct 19, 2005
    1,283
    Jasper, Indiana
    Yeah, that's what I was thinking. How do you adjust them? I screwed them down to where the original ones were. Is there a real big concern about adjusting them?
  6. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I consider it important to follow the recommended torque procedure when installing new ball joints. I forget how it goes, but there is a certain sequence that everything needs to be tightened in.
  7. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
