how to adjust clutch on 88?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by misfit, Oct 22, 2001.
  1. misfit
    misfit 1/2 ton status
    Jul 21, 2000
    324
    south central wa state
    the clutch feels like its either on or off, it engages at the very end of the pedal travel. so id like to adjust it. but how? i see no linkage to mess with down by the clutch fork or anything, annd inside i dont see anything to adjust on the pedal itself. its an 88 with a 465, 350,208 if it matters.....
  2. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    Sounds like you have a hydraulic clutch, and if so, there is nothing to adjust.
    Check the fluid reservoir (drivers side fender wall I think). If it's fine, then it's either normal, or you have a bad component (clutch itself, clutch master cylinder, etc ...)
    Good Luck,
    Thomas.
    -- '84 1-Ton Blazer --
    When the goin' gets tough,
    the tough go 1-Ton [​IMG]
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    I stand behind what Stoop said. Check the reservoir for fluid level. '85 on up manuals used hydro clutches and you cannot adjust them.
    I'm not picking my nose...I'm just pointing at my brain!! [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
  4. Sparky87k5
    Sparky87k5 1/2 ton status
    May 6, 2001
    726
    Lynden, Washington, 4 miles from Canada
    Now my 87 has the hydraulic clutch and the rod that goes from the slave to the clutch arm is adjustable. I adjust it so that I disengage clutch about 2" from the floor. Allows for more free play and less wear on throwout bearing. I have about 1" play in the pedal before the clutch arm begins to move.
    A good firm grip is my idea of gun control!
