how to adjust np203 linkage
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mofugly13, Dec 14, 2002.
  1. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    My case works ONLY in 4loc. All others are like neutral. I went went to adjust the linkages like it says in the Chiltons manual. The manual says to insert a drill bit into holes in the shift lever when they're both lined up in neutral. I do not have one of these holes. The rest of the adjustment looks pretty straightforward, but how do I make sure both shift levers are in neutral? Also, are there rebuild kits for np203's? where do I get one, and can it be rebuilt while still on the vehicle?
  2. Blazerfun
    Blazerfun Registered Member
    Dec 9, 2002
    11
    Monterey, TN.
    If its a factory shifter the hole is there. It can be tough to see. As you are underneath the truck the hole is on the passenger side about half way up the shifter housing. If 4loc is the only one that works it sounds a bit more serious, unless the shift linkage nuts or snap ring is loose. Usually if its just the linkage adjustment the 4 low and 4 high will kick out of gear. There are kits out there for the 203 but they are getting harder and harder to find. 4x4parts has a good kit. You do have to drop it in order to rebuild it.
  3. mofugly13
    Oct 6, 2002
    2,813
    San Francisco
    I meant to say HiLoc, not 4Loc. But, for the life of me, I cannot see this hole,, I'm gonna go to the wash tomorrow and blast it with the pressure washer, but I scraped it off pretty good and I cant find that damn hole...
    I'll be back later with some questions on the install of a part time kit. Thanks fellas.
  4. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    sorry to be OT but mofugly is the funniest username i've ever seen!!!! /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
