How to Air Up Tires?
Discussion in 'The Garage' started by TONYP, May 10, 2003.
  1. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    how the hell do you air up a tire thats not sealed to the rim. 37" x 12.5" x 15" tire on a 15'x 10" rim. I thought I read that the truckers spray starter fluid and light them to set the bead... /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif
  2. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    I tried the start fluid once. ONCE! I'll never try again. Apparently when I started this attempt in the morning it was cool. As the day progressed with no luck and got warmer the evaporation rate of the fluid changed. That is bad news. It went from a flamy wump to a explosive kaboom! Three weeks before all the hair grew back on my arms. If you try this be very careful. I would advise against it. Take it to a garage. Most of them have a cheetah gun. Basically an airtank with a quick valve. Much safer. They did my stubborn tire for free. Just my .02
  3. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    Get a racket strap and put on the outside of the tire so that as you tighten it up I will squeeze the middle of the tire (the tread area) and push the beads of the tire out. Then apply air till they start to set then take the strap off. Then air them up I have done this with my tire and it worked great.
  4. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    First try a ratchet strap around the tire.
    If that doesn't work try the starting fluid
    I sprayed 2 quick laps around the rim, ran a "fuse" shot of starting fluid away from the tire and lit the "fuse". I had the core out of the valve stem when I did it. Put the air hose up to it right when it seats or as it cools it will pull the tire back away from the bead.
  5. SCOTTS_4X
    SCOTTS_4X 1/2 ton status
    Mar 22, 2002
    129
    Modesto CA
    if you are going to try the starting fluid thing, do it right, none of this flame thrower crap, you have to get too close to the tire for that. just spray it into the tire and stand back and strike a match as you are throwing it into the tire, MUCH better option if you as me, and simple.
    -Scott
  6. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    I thought that only worked when its cold outside?
    I usually just stand the tire up and push on tire while filling air. It will usually catch.
    Never tried the strap around the tire but it sound like the same deal just a little more setup.
    /forums/images/graemlins/thumb.gif
  7. TxK5Blazer
    TxK5Blazer 1/2 ton status
    Aug 13, 2000
    593
    Floresville, Tx
    I have to agree with Ringmaster I have used the ratchet strap and it works great for those sturborn tires. They even use this at work sometimes...Jason
  8. TONYP
    Aug 13, 2002
    2,116
    so cal
    thanks guys...
  9. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    I just did the starting fluid trick on my motorhome a couple weeks ago. Worked fine. Lube the bead first w/ some windex or something.
  10. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    give it a blast of air from a co2 tank.
    j
