How to beef up 1/2 ton axles
Discussion in 'The Garage' started by la_blazer82, Aug 5, 2004.
  1. la_blazer82
    la_blazer82 1/2 ton status
    Apr 12, 2004
    148
    SoCal
    What could I do to make my f/r 10 bolts hold for a while. I'm adding 35" ProComp MTs and thinking of going with a 6" Superlift. Would it be better to go with a 4" lift, and could I use 16x10 wheels with one? I don't want to have any driveline issues, but know that the 6" will be good to go.
  2. firefighter184
    firefighter184 1/2 ton status
    Apr 5, 2003
    2,763
    The Barrio
    six inch and 35's will look as lame as my four inch and 33's. Go with a four inch. That SHOULD eliminate driveline worries. As far as beefing up your 10bolts, well, it can be done... but the cost of axleshafts and all the other heavy duty stuff would cost WAY more than swapping in 3/4 ton axles.
  3. cochino12
    cochino12 1/2 ton status
    Dec 23, 2003
    563
    Parker, Co
    I'm in the same position but I dont want to buy new wheels. Can I make the 3/4 axles 6 lug?
  4. la_blazer82
    Apr 12, 2004
    148
    SoCal
    I plan on re-gearing to either 4.10 or 4.56 and adding a LS or e-locker. I'll be using this as a daily driver (although I drive about 10 miles per day), will be doing mild to moderate offroading, and one or two long drives per year. This may become a full-time trail rig, but not in the immediate future.
    What's the going price 3/4 ton axles: will probably consider a D60 for the front, and a 14 bolt for the rear.
    I was told that I couldn't run a 16x10 wheel with a 4" lift. Would I have to add a ORD 1" zero rate lift? /forums/images/graemlins/confused.gif
  5. lifethroughdeath
    lifethroughdeath 1/2 ton status
    Jan 26, 2003
    300
    New Bedford, MA
    Yes you can, but it'll be cheaper to just grab some stock 8 lug wheels while you're at it. TONYP a member here makes the 8 to 6 lug adapters BTW. If you do a search a week or two back, someone (crazy427?) posted on making a 14b 6 lug with these adapters.
    Nate /forums/images/graemlins/k5.gif
  6. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    you can get an 14ff then convert it to 6-lug there's a member on here that make them IIRC. you can always sell you rims.
  7. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    lifethrudeath, you beat me to the punch /forums/images/graemlins/histerical.gif
  8. lifethroughdeath
    Jan 26, 2003
    300
    New Bedford, MA
    I found the link for you 6 lug
  9. la_blazer82
    Apr 12, 2004
    148
    SoCal
    I hear that the front 10 bolt is a bit stronger than the rear. Should I consider swapping in a 14 bolt rear and keeping the 10 bolt front, and just match the gears? Although, I'm either going to have to get 8 lug wheels for the rear or try to add a spacer.
    Should I consider going with either a 4" TC/Superlift spring up front, and ORD Shakle flip in the rear, instead of the 6" Superlift. I want to be able to fit 10" wide wheels.
  10. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I am going to swao in my rear for a 14bff and keep my front 10b since the D60 are so expensive(1K range), as for the lift I would go TC springs in the front, they flex and ride very good, for the rear the ORD shackle flip is nice, I would go with the 6" cause later down the road im sure you will want to get bigger tires just use a 2" block under the oRD shackle flip or buy new 2" springs for the back and that will net you 6" of lift.
    My .02.
    -Chris
  11. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Beef up 1/2 ton axles /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif
    Put them into a Sammi /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/whistling.gif
  12. jekbrown
    May 19, 2001
    45,026
    360
    Vancouver, WA, USA
    for the price of new gears, installation, and a good LS you could have a dana 60. /forums/images/graemlins/grin.gif ff14bs are cheap... and making a rear 10-bolt trail worthy isn't. I highly recommend atleast swappin in a 14 bolt.
    j
  13. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    Ask Robzilla what he did. He has the gnarliest Blazer I have ever seen that he puts into and out of places that I can only dream of.
  14. therobzilla
    therobzilla 1/2 ton status
    May 15, 2001
    1,307
    Gilbert, AZ
    To make 1/2 ton last, just wheel smart, use good ujoints and stay off the gas and don't push the rig, when it feel like it's bound up, get off the gas.
    Now is did finally get CTM's and Superior Crmo Axles for the Dana 44, but I run 35" MTR's and a Doubler with 4:10 gears, and I have a few hours of seat time that allows me to understand exactly what my rig will do and what it won't do.
    It all about the skinny pedal and the seat time fellas.
    1/2 Ton baby!!!! Don't go out and spend a lot of cash without doing some wheeling with what you have first, get some seat time before you decide what to upgrade first. Gear always first in my opinion.
    Have fun and good luck.
    Rob
  15. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    put huge beefy tires on /forums/images/graemlins/thumb.gif
  16. gzzgfw
    gzzgfw 1/2 ton status
    Feb 26, 2003
    505
    Rob
    I'm glad to see this post, most of the time people would say get rid of the 1/2ton stuff.....
    The 60's and 14b are cool and stronger but I gotta tell you that I think that I've been able to climb some stuff or positition better because of weighing less than similar equiped vehicles with 60's & 14bs.
    Right on /forums/images/graemlins/thumb.gifwith the skinny pedal, knowing you truck and keeping caps on the front u-joints from spitting out or cracking. Wheel it and have fun with it.
  17. la_blazer82
    Apr 12, 2004
    148
    SoCal
    So if I were to keep the 1/2 tons, what should I do to them to run 35s, other than gearing and maybe lockers. /forums/images/graemlins/dunno.gif
  18. gzzgfw
    Feb 26, 2003
    505
    My suggestion is in order, 1. locker rear, 2. gears, 3. something upfront, prefer a S.L. for a 10b, 4.then setup rear disc brakes. Some good u-joints, I prefer sealed non greaseable, and always, ALWAYS carry a spare locking hub!
  19. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    also.... what rear axle you got?
    There are 28 and 30 spline 10 bolts. You would be better running the 30. Or maybe you have a 12 bolt rear which is already 30?/forums/images/graemlins/dunno.gif
    and as to this: [ QUOTE ]
    I don't agree.... You'll prolly be breaking the front more than the rear. S'ok.. Just carry spares and the tools to change 'em.
    Marv
  20. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
    With 35's I would run it till you break it. After you break the rear run a 6 lug sf 14 and be done. That way you can keep your rims if you have a nice set. I would regear then lock it up and not worry about the front 10 just drive smart and leave it open shouldnt have much of a problem unless you like to jump with the hammer down. If it does break fix it once and start saving for the 60. A 6" lift with 35 looks good and you wont have to do as much /forums/images/graemlins/hack.gif you will still need a little though. Even with a 6" you might need to do your drivelins, if you dont dont expect the splines to live as long. Or you could just lower the tc a little.
    I ran a 6" when I had 35's and didnt do my drivelines. When I got around to it the splines on my rear shaft were really sloppy, they wouldnt lengthen it for me caust it was shot.
