How to "break in" new gears
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by '73 K5, Apr 13, 2000.
  1. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    How to \"break in\" new gears
    I'm getting new ring and pinions installed as I type this. The stuff I got with the set-up kit said to drive it real easy for the first 50 miles, no towing for 500 and then to change the lube after the first 500 or so. No problem. Question is, how do I break in the front gears? Since I want them broken in before I take it offroad, should I lock the hubs and drive around for a while like that or should I leave the hubs "free" and put the transfer case in 4 wheel drive? Both options will turn the gears right??? I know tons of you guys have swapped gears, what did you do?
    '73 K5
    Chevy good...Ford bad
  2. BIGJ
    BIGJ 1/2 ton status Author
    896
    Central Arkansas
    Re: How to \"break in\" new gears
    The best thing to do would be to find a dirt road to use. My instructions said to drive for 10 miles then let the gears cool. Then do the ten mile thing again and let em cool. The dirt is more forgiving than pavement and I wanted to avoid driveline bind as much as possible considering how long I had to drive. If that is not an option then I say lock the hubs in but not the t-case. It shouldn't bind if you do it that way. I personally like the dirt road thing b/c it gave me an excuse to get out of the city for a while. Damn traffic is a pain in the a#$ some times.
    BIGJ
  3. ggallin13
    ggallin13 1/2 ton status
    Mar 31, 2000
    199
    Northern Nevada
    How much is did your new r&p's cost? What tires do you run, and which ratio did you go with?
  4. '73 K5
    1,763
    Kansas
    Lets see. Here goes
    R & P front: 170
    R & P rear: 160
    Both install kits: 180
    Eaton LSD with spring upgrade: 450
    Moser axles: 225
    New carrier for front: 90
    ARP stud kit for rear bearings: 20
    T/A Performance Diff Cover rear: 160
    It has on the wimpy 235/75 tires now, but I wanted to swap the gears before I did the lift and new tires. I'm 99% sure I'll be buying 33x12.50 Swamper radials in the next few weeks. Even if they aren't the Swampers I decide on, I've got to go with 33's.
    And the gears are (technically) 4.09 front and 4.11 rear.
    '73 K5
  5. shaggyk5
    shaggyk5 1/2 ton status
    1,610
    SE pennsylvania
    ummm.....shouldnt you have the same ratio front and rear?
    shaggyk5
    aint nuthin in the world like a heavy chevy!!
  6. K5Junkie
    K5Junkie 1/2 ton status
    Mar 29, 2000
    499
    Gulfport, MS
    i would think you should run the same gears front and rear.
  7. '73 K5
    1,763
    Kansas
    Duuuuuuuuuuuuuudes. Those ARE the same gears. 4.09, 4.10, 4.11 gears are so close to being the same thing, gear places don't usually seperate them. What do you think I'm smoking crack? Nope. Dana/Spicer makes only 4.09 gears for the Dana 44, not 4.10 or 4.11. And U.S. Gear only makes a 4.11 gearset for a 4 series carrier for a 12 bolt truck axle. I probably could have found someone that made 4.10 or 4.09 for the rear, but I wanted U.S. Gear and I didn't need to. Think about it. When do you use 4 wheel drive? When there is copious amounts of slippage between the tires right? Mud...sand...dirt...etc. That way the tiny difference in gears won't matter anyway. Even if I did have exactly the same ratio in both axles it still wouldn't be perfect enough to drive in a straight line on pavement. The tires are never exactly the same size and the rims and other stuff like slop in the driveline. Thats why there's a differential inside the NP203 to make up for those problems since its used on pavement.
    A lot of people do the same thing just because the gears sets won't match perfectly. Sorry for the confusion. Next time I'll keep it simple and just say I have 4.10 gears.
    '73 K5
  8. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    As a matter of fact, I read somewhere that some serious mud competitors run a numerically lower gear in the front than in the rear. That makes the front wheels turn faster, which helps them steer much better. I was surprised at this when I found out, but it does make sense.
    <font color=black>//////
    What the heck!...Drive it like gas is $0.50/gal!!!
    </font color=black>[​IMG]
  9. '73 K5
    1,763
    Kansas
    Right on! I've heard it both ways. Like you say and I've also heard of guys running higher gears up front so the front tires turn slower so they don't dig in as much and bury the nose of the truck. The rearend pushes the truck, but the front can still steer a little bit.
    '73 K5
  10. KP3100
    KP3100 Registered Member
    Mar 26, 2000
    24
    Beat the [censored] out of them, get them ready for what is to come
    1990 and bad ass!!!
