How to build your own Chassis Dyno
Discussion in 'The Garage' started by ntsqd, Jul 17, 2004.
  1. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Chassis Dyno
  2. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    that looks like a deathtrap!! /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif
  3. uao85
    uao85 1/2 ton status
    Jan 2, 2004
    1,867
    Edge of insanity
    That is awesome, talk about working with what you got.
    Remington
  4. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    LOL thats an interesting idea... kind of dangerous though /forums/images/graemlins/dunno.gif
  5. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    That's definately a Rednecks dyno. /forums/images/graemlins/rotfl.gif
  6. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    yeah I was just thinking I want to drive my nice car off a little ledge and hope I hit some tires before smashing my subframe and components.... /forums/images/graemlins/rotfl.gif
  7. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    That's just brilliant!!! I love stuff like that.
  8. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    i see how it works, but you cant really figure out how much hosepower you make, but it ill certainly let you load it up and break it in good.
    EDIT
    Ahh i see the device there, that will certainly tell you the load, but id like to know how you do determine the HP-tq numbers.
  9. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    just noticed the tire doesn't seem to be bolted to that truck axle /forums/images/graemlins/ignore.gif /forums/images/graemlins/1zhelp.gif
  10. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Shouldn't the truck tire have some lugnuts for safety /forums/images/graemlins/dunno.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
  11. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    that would be what I meant it just came out stupid /forums/images/graemlins/ignore.gif /forums/images/graemlins/1zhelp.gif
  12. ben427
    Mar 10, 2002
    1,123
    Nah they just used the inner Budd wheel, The inner lug nut is threaded on the outside and has a square head on the end of them for intallation. The outer rim goes over the inner nuts and normal nuts go on over them. /forums/images/graemlins/thumb.gif
  13. bigburban383
    bigburban383 1/2 ton status
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    EDIT
    Horsepower is nothing more than torque at a certain RPM. A dyno is really a torque-o-meter, than a computer calculates HP automatically.
    A homemade engine dyno would be really easy to make. You just attach a brake rotor to the fly wheel of and engine on a stand and the caliper kept from spinning by a dial type torque wrench. Then you set up a tach next to the dial guage and have a laptop with a video camera watching both readings. You get the engine up to full throttle braking at the same time, holding rpms in different intervals across the RPM range of power you want to plot. Then you go back and watch the video and record the givin torque and an RPM and calculate your HP. Of course their are little things like converting the torque readings due to a torque arm in your caliper set up. I mean you could buy a torque meter, but they are very expensive. Oh, a high pressure water cooling of the brake rotor is recommended or you may warp your rotor /forums/images/graemlins/tongue.gif
    Torque x RPM / 5252 = HP
    You notice, on every single power plot you'll ever see, the torque and hp lines will always cross at 5252 RPMs, if they dont your looking at a BS plot.
