how to buy an axle
Discussion in 'The Garage' started by showmeburb86, Oct 12, 2006.
  1. showmeburb86
    showmeburb86 Registered Member
    Oct 7, 2006
    17
    Kansas City, MO
    In looking to buy a 14bff to replace the corp. 10b on my 86 sub, what all do I need? Do I need drums and all? If I go to a junk yard and find one on a burb, what all should I take home with me? Just unbolt the springs, schocks, etc and drag it all home?
    Dumb question I'm sure: Do the front and rear gear ratios need to be the same?
  2. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    get the u-bolt plates. they are bigger then the 10 bolt ones you have now. get the front axle to so the rations match or you can at least swap the 8 lug hubs.
  3. broc944
    broc944 1/2 ton status
    Sep 23, 2005
    1,660
    Northern Minnesota
    As far as I am aware of, you will not find a 14bff on a Burb.
  4. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Why not?
  5. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    not on a 1/2 ton burb you wont, but you're gauranteed to find one under a 3/4 ton burb.
  6. Avery4jc
    Avery4jc 1 ton status Premium Member GMOTM Winner
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    well thats bad news, lol
    I'm buying a 14ff out of a burb from JP0863 in the next couple of days.
    -Avery
  7. broc944
    Sep 23, 2005
    1,660
    Northern Minnesota
    I stand corrected. I thought only 14BSF are to be found under stock Burbs.
  8. dremu
    Feb 27, 2000
    15,958
    452
    East of San Francisco
    New ones, yes. Older ones -- obviously 3/4's -- came with the FF.
    -- A
  9. broc944
    Sep 23, 2005
    1,660
    Northern Minnesota
    What is the cutoff year between FF and the switch to SF?
  10. dremu
    Feb 27, 2000
    15,958
    452
    Sheeeeit, I *knew* you were gonna ask. I was gonna put in there "sometime" to be more precise =))
    It's like early 80's, I think. I know my '90 Burb had the SF, and the late 70's ones had the FF.
    Might also depend on GVWR, and phase of the moon.
    -- A
  11. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    it is ABSOLUTELY important to have the gears the same. only thing is that, for instance, a front gear ratio of 4.11 and a rear of 4.10 is ok. apparently being off by a hundredth isn't a big deal. they were available stock like this (its what i'm currently running). don't know if, for example, the 3.73's are 3.74's up front or any other combination of gear ratio.
  12. bowtiepower00
    bowtiepower00 1/2 ton status
    May 11, 2000
    924
    AZ
    Burbs with the BBC or Diesel will probably have the FF. You don't have to have a Burb axle, one from a 3/4 ton truck will work. A 1-ton FF will have the spring mounts in a different location. You are going to want one from a non IFS truck too (pre-87 in trucks, 91 in burbs and Crew cabs). 88-91 or so has a reinforced ribbed pinion support, but this is not really a big deal. I would look for one off of a 4x4, as the 2WD axles may be a bit narrower. You may want to measure just to be sure. The easiest way might be to scan the classifieds here at CK5 until you find one close to you, or post a wanted ad. Should be able to get one for anywhere from $100-$500 bucks, depending on condition, etc. I would look for one with an open carrier so that you can put a detroit locker in it. Also, depending on the condition of the drum brakes you may want to consider a disk brake swap, particularly if your rig is an automatic.
