How to cal. cubic inches?
Discussion in 'The Garage' started by Cornfield creations, Jul 31, 2006.
  1. Cornfield creations
    Cornfield creations 1/2 ton status
    Oct 19, 2005
    1,283
    Jasper, Indiana
    I wanted to know how to calculate cubic inches on a small block.
    I have a 327, bored .060 over, 9:1 aluminum flat top pistons and double hump heads, 64cc chamber.
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    Bore x Bore x Stroke x .7854 X the amount of cylinders (8 in this case).
    A 327 bored .060" is now a 336.6
  3. goldwing2000
    goldwing2000 Guest
    That's a weird formula. It seems to work but it's weird.
    I've always used the area of the bore (pi x the radius²)xthe strokexthe number of cylinders.
    Where do you get that .7854 constant from?
  4. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    It appears to be based off of the square root of 1/2 of the bore/pi (hence the double multiplication of the bore)
  5. goldwing2000
    goldwing2000 Guest
    Man, that's complicated. :confused:
    I'll stick with regular geometry. :D
  6. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    Thats about the extent of my knowlege of it - If you want more detailed info than that I can ask my 1-semester-away-from-a-math-degree wife :D
  7. goldwing2000
    goldwing2000 Guest
    Nah. I'm good with old "pi r squared". That's the way I was taught back in 1989, so that's what I'm going to use!
  8. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    i always used the .7854 constant, i learned it that way 15 yrs ago
  9. BigBen
    BigBen 1/2 ton status Premium Member
    Nov 14, 2002
    1,194
    Grand Haven, MI
    area is pi * radius^2
    If you use bore, you are using the diameter.
    area is now pi* (diameter/2)^2
    Factor out the denominator and you have:
    pi*diameter^2/4
    or, diameter^2 * (pi/4)
    pi/4 is........................................
    .7854
    brought to you by the 'magic of math'!
    -Ben
  10. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    I knew it was something like that but havn't done math like that since 1998 so I couldn't work out the equation..... :D
  11. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I always forget the formulas , but I always remember every .030 is around 5 cubes for an 8 cylinder ( round up for advertising ) :thumb:
