How to change spindle bearing?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by muddbogg89, Apr 1, 2002.
  1. muddbogg89
    muddbogg89 Registered Member
    Mar 19, 2002
    97
    Chicago(suburbs)
    I am replacing my rotors and wheel bearings, how do I change the spindle bearing?Any tips for putting it all back together?
    thanks
    89 K-5 warn hubs
  2. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    Re: 2 or 3 bearings in front wheel?
    there is a 3rd bearing if you take your spindle off. your axle shafts rides on that 3rd bearing as it goes through the spindle.
  3. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    There are only two wheel bearings on each rotor. The guy may have also sold you the spindle bearing which the outer axle rides on, this bearing is a torrington bearing not like the wheel bearings and it is only about maybe an inch and a half in diameter with needle bearings in it. The outer bearing will just fall out of the hub once you have the nut off.
  4. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    Yes just did them last night (lol) and it will just fall out when you losen everything else...mike
  5. muddbogg89
    Mar 19, 2002
    97
    Chicago(suburbs)
    o.k. I see ...I'm the idiot!
    thanks for your help
  6. muddbogg89
    Mar 19, 2002
    97
    Chicago(suburbs)
    How do I get the spindle off to change it? sorry I'm new at 4x4's
  7. 86K5TrailBlazer
    86K5TrailBlazer 1/2 ton status
    Apr 24, 2001
    436
    Orange,CA
    you unbolt it and whack it, but be sure not to mess up the surface of where the bearing rides on the spindel
  8. muddbogg89
    Mar 19, 2002
    97
    Chicago(suburbs)
    Thanks!
  9. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    I don't think that anyone has answered your question yet. Once you remove your spindle from the knuckle. you will see the needle bearing inside. Hit it with a punch from the inside of the spindle towards the outside. you don't have to be carefull with it since you are replacing it. Once you get it out and clean everything up, get a socket or something that is the same diameter as the bearing and tap it in carefully. Make sure you are going in evenly and not at an angle or you will damage the beariing. Grease it up real good and replace both seals(since it's already off) and your done.
  10. shaggyk5
    shaggyk5 1/2 ton status
    1,610
    SE pennsylvania
    word of warning, when punching it out from the inside, BE CAREFUL not to break the bearing apart. I did this and busted the bearing apart till it was just a flat metal ring inside the spindle. Took me a week to get it out.
