How to? Changing front output shaft in 205
Discussion in 'The Garage' started by BigOrange90Jimmy, Aug 3, 2005.
  1. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    Just found out that my 205 in my truck has a 10 spline front output. I need to either convert it to the 30 spline shaft so that I can run my flange, or just find a u-bolt style driveshaft. Help me out fellas.
    I've never torn into one of these t-cases, so my knowledge is limited without any manuals. How do I do this and can it be done quickly?
  2. white-rhyno
    white-rhyno 1/2 ton status
    Jan 27, 2002
    942
    Ellensburg Washington
    I did my swap while in the truck. Its not that hard. Its alot better with two people.
    First, drain the case........ dont ask, i forgot
    second, take off the yolk. Impact gun works nice. For that i cheat and put it in 4wd. Be sure to put it back in 2wd, it might not matter, thats just how i did mine.
    Third the cover right behind the front out put, take it off. This will leave you looking at the back of your front output, youll see a huge gear. You should then be able to slide out the shaft, a collar and a washer (i think) should fall off. Note the order, i dont remember.
    Now, when your putting the other shaft in, have someone with long fingers hold the washer from the front.
    I just dove into the project one night. and everything still works. Its a bit interesting putting it back together. Youll do fine,
    This might not be the best "how to" but its easy
  3. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    your goin to need a strong impact to get it off.i dont know what my dads is rated at but it wasnt enought to get mine off.
  4. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    its pretty easy/straight forward... there is prolly a write up somewhere here or on pirate. Only prob I had is that there is a big snap ring that is a royal biatch without the right tools. I spent an hour trying to get that thing off... then threw up my hands and took it to a local shop, they popped it off for free in like 10 seconds. lol!
    j
  5. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    i've got the nut and the yoke off. my 3/4" drive sockets and ratchet took care of that.
    i'm just trying to decide what to do.....
  6. mr_clean
    mr_clean 1/2 ton status
    Sep 21, 2003
    348
    Sacramento, CA
    good article on how to rebuild...
    here's an article with pictures that I used to rebuild my 205. As long as you don't mind it's a F**D site... :rolleyes:
    Clicky
    Scott
