How To Charge Fox Shocks???
Discussion in 'The Garage' started by tacomuncher, Apr 12, 2006.
  1. tacomuncher
    tacomuncher 1/2 ton status
    Jan 3, 2006
    110
    goleta ca
    A while back i did a trade with a guy for some 14 stroke fox shocks . one is missing a resivor and they have valves on them similer to a tire valve. I have no idea how to charge them. ill try to put up some pix after work.
  2. blk87K5
    blk87K5 1/2 ton status
    Dec 26, 2001
    1,290
    Lubbock, Texas
    Charge with Nitrogen to 200 psi.
  3. tacomuncher
    Jan 3, 2006
    110
    goleta ca
    how do i put oil or atf and what order nitro then oil or oil nitro?
  4. blk87K5
    Dec 26, 2001
    1,290
    Lubbock, Texas
    Call Fox and ask them how much oil to put in. It vaires depending on shock.
    To put the oil in, pull the schrader valve and squeeze how ever much oil in with a syringe. Fill with oil first, then charge the right pressure.
    Use Fox shock oil and NOTHING else. If you have Swayaway shocks, use their oil.
  5. tacomuncher
    Jan 3, 2006
    110
    goleta ca
    thanks for the tips its gonna help out a lot
  6. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    umm...how/ where do you chrage shocks with nitro...:confused:
  7. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    buy the stuff to do it yourself, off road shop, or a motorcycle shop(dirt bikes).
  8. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    Send them in a get them repaired right the first time. Fox or any off road shop that does service can help you out. It's not just throwing any type of oil in and charging it with nitrogen . It's a little more complex than that, like bleeding all the air out of the shock while replacing the oil with the right stuff. Good luck!
  9. blk87K5
    Dec 26, 2001
    1,290
    Lubbock, Texas
    :haha: And just exactly how do you do that? :haha:
    Shocks arent that complicated, and yes it is as simple as pulling the schrader valve, dumping the old oil out, refilling to specs, and charging with nitrogen. No shock company will ship a shock charged, therefore whatever you do, you will need a source for nitrogen. If the shock needs to be rebuilt, send it off if you dont feel confident, but all shock manufacturers will sell rebuild parts and have exploded diagrams.
    Dont start throwing money at your shocks until you know exactly what you need.
