How to check 10bolts to see if they are 30spline w/out pulling cover???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Nrose07, Apr 12, 2002.
  1. Nrose07
    Nrose07 1/2 ton status
    Mar 29, 2000
    267
    Salem ,Or
    Want to double check to see if I have 28 or 30 count with out tearing them apart. Anyone know the codes and their location?
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Look for one from 89-91. They are supose to be 30 spline. There is no way to know without pulling the axle.
    Dan
  3. dyeager535
    26,979
    I don't recall if the axle tube stampings indicate year, but they may have a date stamp as well. The codes seemed to change every year (or fairly often) so that might narrow it down. (rear axle) should be on passenger side tube, facing towards the front of the truck, about halfway between the differential and the tire
  4. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Sounds like a good time to change your rear end fluid. Pulling the axles really isn't that hard. First time I did it, it took maybe 15-20 to figure out how to do it and have them out. Its nice to know how to do it anyway.
