How to check gears?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ChevBlazin, Mar 12, 2002.
  1. ChevBlazin
    ChevBlazin 1/2 ton status
    Feb 4, 2002
    332
    St. Paul area, Minnesota
    Ok, heres the deal. I just got my new axles today which have 3.73 gears in them, so I'm told. He said he "spun" the axle to see what was in them. I thought I knew how to do this, but now i'm confused. If I spin the drum on one side one full turn the yoke almost makes a full turn, about 90-95% of the way around. And vice versa if I spin the yoke one full turn the drum goes just past one full turn. How do I figure my ratio from this? Does this mean I do have 3.73's, or are they something else? I know pulling the cover is the best way, but I'm away from home now and am wondering if the 3.73's are really what I have. Also if the gearing means 3.73 to 1, right?, what is it that is spinning 3.73 times for every 1 turn of something else? (if that makes any sense at all) Thanks for any help that can be given.
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    3.73 to 1 = For 3.73 turns of the drive shaft(pinion gear) the Axles(ring gear) at the wheel make one complete turn.
    To check it without removing the cover. Turn the pinion shaft (where the drive shaft connects) and count how mant turns it takes to make the drum/axel make 1 revolution.
    EX: pinion shaft turns 3 3/4 times to 1 drum revolution = roughly 3.73 to 1 .
    But its best to pull the cover. The ratio is stamped on the ring gear. Plus you can see if the axel is worn out or not.
  3. StonerK5
    StonerK5 1/2 ton status
    Feb 13, 2002
    183
    Phoenix Arizona
    I agree with Thunder, it is best to pull the cover since you just bought them, you need to know what is going on inside there. I think that doing the rotation stuff is for when you are searching for axles in the junkyard and have like 30 to go through.
    Look to see if the gear oil is burnt, or really brown. If it looks like chocolate milk then there is water in there and needs to be cleaned out and changed.
    Get some brake cleaner and squirt it inside to clean everything off. Like Thunder said, the ratio is stamped on the ring gear. Out of all the numbers the ratio is near the end... should say 41:11 then the date the gears were made.
    41 divided by 11 is 3.73 actually it's 3.7272727~
    Chris
  4. ChevBlazin
    Feb 4, 2002
    332
    ok, sounds good guys. I am going to pull the covers when I get home this weekend, but was just curious about how people spin them to check, makes sense. Thanks
  5. Chris_T
    Chris_T 1/2 ton status
    Mar 17, 2001
    718
    Saskatoon, SK
    Remember, if it's an open carrier that only works if you have both wheels off the ground. To do it with one wheel off the ground you have to spin the tire twice.
    C
  6. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    I think everyone is on the money, but it surprises me that nobody pointed out the most precise way of all. Sometimes the gear ratio is on the ring gear, sometimes its stamped on a little tag. You can always count the number of teeth on the ring gear and divide it by the number of teeth on the pinion gear.
  7. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    79Beast... read the 2nd and third post. They did tell him that.
    /forums/images/icons/smile.gif
    Ken H.
