how to check if shocks are worn
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bajaviking, Jul 11, 2002.
  1. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    I have Rancho 5000's and I think one of them might be worn out. If I take it off how do I know if it's worn out. I think gas shocks are supposed to extend by themselves if you push them in but I think Ranchos are oilfilled and they don't.
  2. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    I've always checked for a bad shock by pushing down on the corner of the vehicle where I think I may have a bad shock. Give it a few good shoves at let go, if it stops bouncing immediatly, the shock is good, if it keeps bouncing like a rubber ball, the shock is bad. Stiff springs may negate this test though.
    John
  3. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    ranchos don't extend on their own i have two hanging in my shed that are sucked in and they stay that way.
  4. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    if the exterior of the shock is getting an oil/ dust film on it, it's usually a sign the seals are leaking and the shock is going bad, as for the movement when trying to compress or extend the shock it should never move freely, if it's really worn out you will be able to push the rod in and out with little resistance, usually they will compress very easliy for a short distance and then develop resistance, this is a sign they are wearing out, new shocks have even resistance at all positions, and are somewhat stiff to compress.
  5. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    Yup. what you said! /forums/images/icons/smile.gif Also, another way to tell, is to have someone drive next to you on the freeway and watch for your wheels hopping. If they do, then your shocks are shot. You'll know wheel hop when you see it. /forums/images/icons/tongue.gif
  6. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color="blue"> Take one off and try to compress it with your hands ...if you can ...no good ! </font color>
  7. bajaviking
    Apr 10, 2002
    752
    Baja
    I could compress them with my hands when they were new out of the box(and I'm not built like Arnold) so I don't think that wil work as a reliable test. I guess the best way is to check for leaks and movement without resistence in the shock.
  8. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Shocks are valved differently for compression and rebound unless it is a steering stabilizer then it should be valved 50/50. It should move one way faster/slower than the other, but regardless of direction the motion should be smooth and not jumpy.
  9. JohnnyFresno
    JohnnyFresno 1/2 ton status
    Mar 24, 2002
    194
    Clovis, CA
    I know a good wAy to test
    If they look old and crappy like mine then it's time for new 1's. /forums/images/icons/laugh.gif /forums/images/icons/tongue.gif /forums/images/icons/grin.gif /forums/images/icons/shocked.gif /forums/images/icons/laugh.gif
