how to clean underbody...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by reddog64, Feb 6, 2001.
  1. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    What's the best way to clean the underbody... ANd what's the best way to protect it/seal it/rust proof it....
    What have you guy's done...
    Um... yes officer I know it's too big...
  2. Impex
    Impex 1/2 ton status
    469
    Chandler, AZ
    What i have used and what others have said that works very well is to get a lawn sprinkler connected to a hose and lay it underneath the truck and turn the water on full blast and let it go to town!
    [​IMG] [​IMG]
  3. JTB
    JTB 1/2 ton status
    Dec 5, 2000
    192
    CA
    I used a pressure washer, a putty knife, and an angle grinder with a wire wheel to do the job. I then used por-15 on the severely rusted parts and an oil-based industrial paint called Iron Clad on everything else. Getting all the dirt and undercoating off took FOREVER, but it was worth it. I'm happy with the results. If I had the cash I would've used POR-15 on the entire underside. It seems really durable and has a finish similar to a powdercoat. I whacked it with a hammer and it didn't crack- that was all it took to sell me on the stuff. Hope this helps.
    Don't drive it unless it says Chevy!
  4. EDdaTREE
    EDdaTREE 1/2 ton status
    Feb 18, 2000
    1,253
    Austintown, OHIO
    It usually takes me a good 3 hours at least to hose off the beast and get the underneath free of mud. I've heard of putting an oscillating lawn sprinkler underneath and letting it sit for awhile but my 76' has so many nooks and crannys that I usually end up with a face full of back-splash when I do it right. Always spray out the rear whl.wells looking forward, there's a big rust and mud catcher there. Heard good stuff about POR-15, Rust-Oleum,Rhinoliner, etc. PS. ALWAYS spray out where the rear wheels roost to, I.E. the back pan and bumper. Soon as ya think yer done.. hose it out for an hour more-time well spent!
    "I'm not stuck...I'm just being as ONE with nature"
  5. lowlevell
    lowlevell 1/2 ton status
    Jun 27, 2000
    343
    Central Ohio, USA
    I used to use a dually Taylormade? forklift to lift the front of my truck up till the back bumper touched the ground.made powerwashing it after a day in the mud easy.But i dont work for that company anymore :(And i dont "mud" anymore.Later...
    One From None
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I once took mine to a shop that put my rig up on a lift and then cleaned the entire underside with an industrial steam cleaner. Those suckers take off a lot of crud! Only cost me $15.
