How to connect wires for factory tach
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by k5king2, Nov 13, 2000.
  1. k5king2
    k5king2 Registered Member
    Nov 13, 2000
    13
    Have HEI and factory tach need to make a harness Help!!
  2. Sparky
    Sparky 1/2 ton status
    Aug 20, 2000
    423
    San Antonio(summer) Texas A and M (school year)
    Get a Haynes or Chiltons. They have good wireing diagrams and cost about 15 bucks at any parts store. Other than that, guess and check.
    When all else fails... Check the blinker fluid.
    78 K-5
  3. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    It depends on what year your K5 is. Fill out your bio or include it in your posts. It's hard to help if you don't give the information to do so.
    Cruisin in my '73.
  4. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    There's a brown wire and a red wire commin through your firewall.. the both go to the distributor. they plug into the dist. cap... the red in one and the brown in the other... On my 1978 they only go in one way so you cant screw it up.
    Um... yes officer I know it's too big...
  5. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    Most tach's come with 4 wires. A ground, a hot wire, a wire for the light and the wire that goes to the distributor. I made my installation easy by just attaching the wires to the fuse block, except for the one that needs to go to the distributor. And most of the distributor caps are marked
    for the battery and tach connection. I can provide a wiring diagram for you if you need it.
