HOW?? TO CONVERT FROM METALIC BUSHINGS TO "RUBBER" ON 66 4x4 SUBURBAN
Discussion in 'The Garage' started by bartamos, Jul 2, 2004.
  1. bartamos
    bartamos Registered Member
    May 15, 2003
    28
    HOW?? TO CONVERT FROM METALIC BUSHINGS TO \"RUBBER\" ON 66 4x4 SUBURBAN
    Can someone please tell me how I can switch to rubber/poly/urethane type front leaf bushings on a 66 Chevy Suburban stock 4X4 and get away from bronze/brass type. What is the first year of rubberized and what part do I need. Can I de-rivet a shackle from some year and bolt it on? And use new type springs? What year do I need? Why doesnt some company make a "rubber" replacement?
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Re: HOW?? TO CONVERT FROM METALIC BUSHINGS TO \"RUBBER\" ON 66 4x4 SUBURBAN
    Rubber sucks. It seizes and then it doesn't work at all. It will also soak up oil and deteriorate.
    Poly might wear out but at least it doesn't seize up or deteriorate from grease.
  3. bartamos
    May 15, 2003
    28
    What I'm trying to say is: How do I get away from the old metal bushing setup and get to NON-METALIC? Like all the other trucks/blazer/etc in later years. I dont mean to discuss what kind of NON-METALIC bushing to use.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I wish I knew, but I know nothing about the older than 1967 chevys.
  5. bartamos
    May 15, 2003
    28
    SOoooooooooo....what do 67 chevys and up have in their front leaf springs?
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Bushings. /forums/images/graemlins/thumb.gif
  7. bartamos
    May 15, 2003
    28
    MADE OUT OF?????????????? Come on Tim Im looking for information here?
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    The stock ones are rubber and in the aftermarket you can get them in poly.
    If you're willing to re-engineer your suspension to a newer or different setup, you can fit any suspension you desire to your truck.
    I'm really not understanding your question. This what I've gathered:
    1. Rubber/poly is not available for your current springs
    2. You want to change this
    3. Your question seems to be, "Can this be done?"
    Answer to that question is yes, it can. As to how, I don't know without being able to see it at least as I don't know what is under your truck. Do you have any pictures of your current suspension you could supply us?
  9. bartamos
    May 15, 2003
    28
    ttt
