How to deal with bump steer???
Discussion in 'The Garage' started by Blazin Ed, May 6, 2002.
  1. Blazin Ed
    Blazin Ed Registered Member
    Mar 29, 2002
    92
    Seattle
    Hey Guys... I installed a 4" lift with a 4" steering arm... When I'm driving on the freeway it still seems to jerk the steering wheel quite a bit everytime I hit a bump. Is there any way to lessen the bs or even eliminate it completely? I miss the smooth steering characteristics I had before the lift. Any advice would be great...
  2. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    dual steering stabilizers may help a bit, but will not get rid of the problem. check your alignment, did u shim your front axle? i think most of us have just learned to live with the condition, be sure to leave your thumbs out of the wheel as you are cruising down the road.
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Need a few more details.
    Do you have a steering dampner?
    Did you hook up the sway-bar? Did you use disconects?
    What angle is the drag link at?
  4. Blazin Ed
    Mar 29, 2002
    92
    Seattle
    I installed 1 ES3000 Pro comp steering stabilizer, didn't do anything with the sway bar ( I did read something about swaybar drop down kits), the drag link seems to be slightly off level... Would the sway bar be a good place to start?
  5. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Who is the lift made by? I had terrible bump steer problems when I put on my Tudd coutry lift. I put on dual stabilizers, and the ORD sway bar drop. It helped out alot, but it was still there. You will learn to live with it. Also the ligther you get your truck the more it goes away. When I took off over 1000 lbs it almost went away.
    Dan
  6. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I dont think the stabilizers have any effect on bumpsteer.
    what sucks is that to reduce bumpsteer you have to experiment.
    that means try a bunch of stuff to see what works best for your truck as what works for me may not work for you.
    I would be tempted to try a 2" drop pitman arm with a factory steering arm.
    then use blocks to raise stock steering arm to see if you can find the sweet spot.
    the swaybar can be used to force the axle to travel in an arc similar to the draglink.
    basicallythe swaybar and draglink must be parrallel. this binds the springs though and I dont like the idea
  7. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    i agree with mj here on this one
    only add how is your "slop" in the gear box to add 2 it its a small factor but none the less 1 2 keep in mind
