How to drill a hole with a taper? *for steering arm*
Discussion in 'The Garage' started by TX Mudder, May 17, 2003.
  1. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    You know how lugnut have an angled surface to them that fits in an angles surface on the wheel? I want to do that.
    My steering arm had 4 1/2 holes already drilled. I want to drill/grind/whatever the cone into the top of the holes. What tool do I use? I plan to take the steering arm off and use my drill press, but I don't know what to use to do the work.
    How can I drill the taper or cone into my steering arm?
    -- Mike
    *update* I measured the angle of the taper - it is 30 degrees. SO I need something that will drill a 30 degree taper for the 1/2 hole. Would a die grinder cone chucked into the drill press work? Seems like that just isn't the right tool.
    -- Mike
  2. bee32
    bee32 1/2 ton status
    Aug 6, 2001
    401
    Virginia Beach Va.
    Re: How to drill a hole with an taper? *for steering arm*
    If you are talking about the Counter Sink, they make a special bit for it. And yes it is called a Counter sink. You can also use a drill bit that is bigger. And just let it start to bite into it. You don't want it to have an edge around it so stop as soon as the teeth start to dig in and keep it perfectly straight or the counter sunk will be deeper on one side than the other. It's used for bolts that have a rounded edge on the bottom side of the head or Countersunk rivets. Just in case you didn't know. We use them alot in Aircraft. If a bolt has that than you need to countersink the hole or else the bolt is not as strong as it should be. Using your press will make it very easy. Hope this helped.
    * The bits they sell should come in different degrees. We use 30 and 45 here at work. *
  3. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    The taper only needs to be maybe 3/8" deep (I will obviosuly measure it when I do it, but I'm just eyeballing the depth because I have a lugnut in my hand.)
    It sounds like the countersink is uses for making a non-tapered indentation, kind of like what a Forstener bit does in woodworking.
    If I'm confused, please tell me because I'd like to just go to the store and find something that will work!
    - Mike
  4. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    A lug nut should have a 60 degree included angle. So you will need a 60 degree counter sink tool made for steel.
    Here is one type:
    These are what I use usually:
    http://calaero.zoovy.com/product/COUNTERSINK5161732
  5. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    Gracias.
    -- Mike
  6. bee32
    Aug 6, 2001
    401
    Virginia Beach Va.
    If you look at the lug nuts they are tapered as well to fit into that countersink. If the bolt you are using does not have that under the head than don't do it. The bits they sell will give that exact angle to any hole as long as you get one big enough.The way we do it is using the countersink bit for about 2-3 seconds then triin the bolt/rivet to see if it is deep enough. You are right about the depth. It all depends on the countersink on the bottom of the bolt or rivet head as to the depth. I work with metal at work and have not delt with wood that much so I am alittle illiterate there. A countersink drill bit DOES do a TAPERED indintation. Just watch the depth. For example. If I drill a 3/8 hole and want a 45 degree countersunk than I would use a countersunk bit that is over 1/2" thick at the biggest part. Or I can use a 1/2" bit. and just barely hit the 3/8" hole with it dead centered and it will give me a 45 degree countersunk. But do not aloow the bit to actually start diggin in. Sorry if any of this confuses you. When teach new people I use the tools to demo and it makes it alot easier.
  7. bee32
    Aug 6, 2001
    401
    Virginia Beach Va.
    Jason nailed it. We have those at work and that is what I was talking about. Sorry if I confused you at all.
  8. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    I believe what he is doing is wanting to use studs and open end lug nuts to hold his steering arm onto his axle. This is the way that ORD makes there steering arms. He will be using a 60 degree lug nut so he needs a 60 degree taper.
    Just countersink a little, test fit, countersink, test fit, etc until you get to the right depth.
  9. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    Thanks for the calrification. It makes a lot more sense now.
    My steering arm is held on with studs. I just have flat nuts on there but am changing them over to lugnuts and am going to put the countersink in there so the lugnut's taper will mate perfectly the steering arm.
    I'm going to the tool store later to see if they have a 60 degree countersink made for metal. If not, I'll order one on-line.
    Thanks again! I learned a lot.
    -- Mike
  10. bee32
    Aug 6, 2001
    401
    Virginia Beach Va.
    Sounds like Jason knows what you are doin. I may have gone alittle too indepth. I do that alot when teaching /forums/images/graemlins/rotfl.gif. I just love working metal. It's kinda like my thing you know. But what Jason said makes it alittle bit more clearer. /forums/images/graemlins/thumb.gif Espeacally about drill alittle and test it. That's how we do it. Good luck. I may try that on mine when I get aROUND to actually re-doin EVERYTHING! /forums/images/graemlins/eek.gif
  11. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    Mike,
    when you go to buy one make sure you get the right angle one, they come in diff angles. And doing it by hand you should get a 4-flute countersink...If your not in a big rush I could mail you one to use.... /forums/images/graemlins/thumb.gif
  12. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    Thanks for the offer Tony - I just ordered one online (local tool place had some 82 degree ones but no 60 degree ones.) It cost $5.95 with shipping.
    What do you mean - doing it by hand you should get a 4 flute countersink? The flutes are the part of the bit that allows to the metal you are cutting to get out, correct? I'll be using a drill press, if that makes a difference.
    -- Mike
  13. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    When doing it in drill press or by hand you want at least 2 flutes. If it's a single flute then the one side is always pushing it off center. If your not using a mill that can keep it centered then it could be problem. With a 2 flute or more it's pushing evenly around it so it centers better. The more flutes, the better it self centers.
    Did you buy a 60 or 82??? And 82 is a normal screw head counter sink and won't work with the lug nuts. You basically defeat your purpose...
    EDIT: Nevermind, I see what you mean, local place only had 82 degree so you bought a 60 degree online. Nevermind /forums/images/graemlins/thumb.gif
  14. keith
    keith 1/2 ton status
    1,158
    La Fayette, GA
    If you are doing it for the tie rod ends those are the wrong ones. /forums/images/graemlins/rotfl.gif Try here
  15. keith
    1,158
    La Fayette, GA
    Oh I see /forums/images/graemlins/smirk.gif You are doing it for the studs. Sorry. I guess i should /forums/images/graemlins/deal.gif
  16. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
  17. TONYP
    Aug 13, 2002
    2,116
    so cal
    nice job Mike, now if I could only get you up this way to put my truck back together... /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  18. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    Snap on sells any kind of taper drill bit you could need. Not too bad on price either. I had one for my old pitman arm on my Jeep to fit Chevy tie rod ends. Easy as pie.
    Ken H.
  19. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    so how does the cap go over that countersink?
  20. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> That's a damn good question... </font>
