How to drop t-case
Discussion in 'The Garage' started by la_blazer82, Sep 16, 2004.
  1. la_blazer82
    la_blazer82 1/2 ton status
    Apr 12, 2004
    148
    SoCal
    I'll be adding a ORD flip and 4" TC springs in about two weeks. I'm also swapping in a 14bff and 10b 8lug. How do I drop down the t-case to accommodate for the lift. I didn't think I needed to drop it; this is why I went with 4" instead of 6" lift that I was thinking about
  2. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Easiest way is the bolts that hold in the crossmember should have spacers above the frame. Take the bolts out and put the spacers between the frame and crossmember
  3. la_blazer82
    Apr 12, 2004
    148
    SoCal
    What kind of spacers do I need, and can I get these at any auto parts store?
  4. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    you didnt read the post. I said it HAS spacers on the bolts above the frame. They just need to be moved below the frame to drop the crossmember
  5. la_blazer82
    Apr 12, 2004
    148
    SoCal
    gotcha! /forums/images/graemlins/thumb.gif
  6. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    There were a few posts on here some time back about using the stock spacers and how it caused the frame to crack. General opinion then was that it was better to use some solid blocks the full width of the cross member. Ally would work well.
    Also, don't drop it too far as the distributor (if you've got HEI) hits the firewall. You can get it close but remember that the engine moves quite a bit when you're wheelin'. /forums/images/graemlins/thumb.gif
  7. Emmettology 101
    May 9, 2000
    8,126
    FL
    Do the lift without dropping it an see how it is, you may not need it. I have done 4" lifts and 6" lifts on K5s, and never dropped a t-case..
  8. vw62rag
    vw62rag Registered Member
    Jan 1, 2004
    78
    topeka, KS
    how do you know if it needs dropped?
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Agreed there. I don't know why you guys are dropping your transfer cases anyway. Your front driveshaft is shorter than your rear and you're killing your front driveshaft angle in doing so.
  10. Emmettology 101
    May 9, 2000
    8,126
    FL
    If you get vibrations in the driveline after the lift....
    I've never been a fan of t-case drops.
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    If you get vibrations after a lift, your angles are wrong. Measure the angles and shim accordingly or move perches. Pretty much a no brainer on that one. Angle finders are $9 at Home Depot and I'm the proud owner of one.
  12. Emmettology 101
    May 9, 2000
    8,126
    FL
    Thats why some do a t-case drop cause they dont have the means to move the perches. /forums/images/graemlins/smile.gif /forums/images/graemlins/grind.gif /forums/images/graemlins/weld.gif
  13. la_blazer82
    Apr 12, 2004
    148
    SoCal
    Not sure that I need to yet, but I was going off one of the "technical" articles on this site, which dealt with changing out 4" blocks for an ORD flip. It stated that if doing this (ORD flip) as a first lift, you need to drop the t-case.
    As I mentioned in one of the posts above, the reason I am going with the 4" opposed to a 6" lift, was that I didn't think I needed to mess with the t-case
    I can buy a degree finder, but what is involved in shimming the driveshaft. In other words, I have no idea how to go about this
  14. 454k30
    454k30 1/2 ton status GMOTM Winner
    Sep 13, 2004
    1,613
    California, MD
    The shimming he is refering to to is the shims that go between the spring perches and the springs themselves. They are little wedge shapped metal pieces that help correct pinion angle. With the flip though you probably wont have to shim unless it vibrates. Even so though make sure it isnt the t-case end of the driveshaft that is binding. That is the onle real reason to drop a t-case down, to fix the output yoke angle. Other than that their is no reason to drop it down because it will screw up your front driveshaft angle.
  15. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I would be willing to bet that the majority of you guys that have lowered your transfer cases are binding your front driveshaft as a result. The engine is sloped back in our trucks about 4* from the factory. Lowering the transfer case 1" makes that more like 6-7*. Of course I don't know every combo that's out there, but I know that with even 6" of lift it doesn't take long before you bind up the stock driveshaft.
    I understand that everyone wants to reduce the operating angle of the rear shaft, and that's great because that's the one that sees all the use, but I would seriously reconsider, because your front shaft is going to work twice as hard as a result.
  16. Emmettology 101
    May 9, 2000
    8,126
    FL
    You could run a degree shim like 454 is talking about in the rear. But moving the perches is a better way.
