how to figure out what kind of radiator and fan...
Discussion in 'The Garage' started by 84gmcjimmy, Sep 6, 2004.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Okay, I wont get these for a long time, but I will be getting an alum. radiator, and an electric fan.
    My question is first:
    How do I figure out what size of radiator I need, ie how many "cores" etc to cool a BB chevy or pontiac. I would rather have overkill, then not enough... I need to consider the width and height, for when I narrow my fenders, I dont make it to small.
    secondly, what kind of fan would be good to cool a large engine like that?
    I will have more questions later, as I dont know anything about radiators...
    like I said, I will not be getting these soon, I just want to know the ideal size, etc. Thanks!
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I personally believe that nothing beats a mechanical fan.
    I would analyze what size radiator came in the vehicle that donates your engine, and go from there with your upsizing. Not running air conditioning helps a lot to gain more cooling.
    I have a 3 core in my truck, with a 4 speed and a decent mech fan and a half ass shroud. It's hardly sufficient for the engine as it is. If I had a complete shroud I think my 3 core would be plenty adaquate for my 350. I guess only time will tell to see what I mess with on my cooling system. All in all, mine is pretty good though. It has never overheated except when my water pump went bad at real truck challenge.
  3. js4x4
    js4x4 1/2 ton status
    Jul 17, 2004
    798
    San Diego, CA
    The only time I messed with my radiator was when I had a 69 bronco, and couldn't find a replacement..had it recored, with a 4 cores vs standard 3. never overheated, and it didn't have a shroud.
  4. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    yeah, if you are going to run elec fans, use factory ones (like taurus or ford mini van) they are hella powerfull. AFA which aluminum radiator, pick a manufacturer and get the biggest one they make. I think Summit sells rebadged aluminum rads that are 2 core, 1" tube all-aluminum jobs that would work well.
    j
  5. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    If you go with a generic aluminum radiator be sure to get one with the transmission cooler lines if you have an automatic transmission. I'd have to agree with using a Taurus or Winstar fan if you're set on electric. I'm using a Flex-a-lite Black Magic fan and an aluminum radiator in my '56 and it just does the job. I'm going to check on the Taurus and Winstar fan sizes to see if one of them will fit my needs.
  6. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    I want to use an electric fan, so on water crossings, or playing in mud, I can turn it off so the mud/water wont wreck the fan blades...
    I will check into those factory fans you guys suggested when the time comes near.. and when I look into a radiator, I will find the biggest one I can, with a tranny cooler line for my th-400 /forums/images/graemlins/peace.gif
    Thanks for th ehelp!
  7. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    you are also making it a crawer too right? you have been talken about a doubler and stuff.
    so rpms and not moveing much right? so over kill as much as posable.
    the 455 pontiacs had a small top flow rad, so a truck sized one will be great /forums/images/graemlins/waytogo.gif
  8. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    yeah it will be for rocks and mud mostly...
    I will do overkill as much as I can...
  9. abcjames
    abcjames Registered Member
    Sep 1, 2003
    38
    Phoenix,AZ
    Late model burbans came with an auxiliary elec. fan that you can pick up from a parts store that sells DELCO much cheaper than most aftermarket fans and can be a puller or pusher.
