How to figure out what motor I have?????
Discussion in 'The Garage' started by dasanii19, Nov 26, 2006.
  1. dasanii19
    dasanii19 1/2 ton status
    Oct 11, 2006
    344
    NV
    The guy I bought my 1976 K5 blazer from told me the truck has a "corvette motor" in it. They guy is no mechanic by any means.
    Anyways, where do I look to find the numbers on my Block to see what type/year motor I have? The motor is still in the truck. I can post back what I find and if it will help to see some pictures I can take some as well. Please let me know.
    Thanks guys
  2. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    block casting numbers are located at the rear of the block, facing upwards, on the passenger side of the block. if it's dirty back there you might have to scrub some grime off in order to fully read the #'s.
    write it down. then go here.
    http://www.mortec.com/castnum.htm
  3. dasanii19
    Oct 11, 2006
    344
    NV
    Thanks man, ill go check it out right now and post back what I find if you care to hear :D
  4. dasanii19
    Oct 11, 2006
    344
    NV
    would you happen to know how many bolts mounts I should have on my torque converter? (Bolting the fly wheel to the TC) I have a TH350 and only count three, I think a few might have busted off but am not sure. "1975 K5 blazer"
  5. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    Should be only 3...
  6. dasanii19
    Oct 11, 2006
    344
    NV
    Thanks. Do they need to be torqued at a certain spec? or loc tite used? washers?
  7. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Three torque converter bolts is normal.
    There is a machined flat pad at block deck height on the front passenger side of the block. I will have a set of numbers plus 2 or 3 letters. Post up this letter code and I can decode it for you. (Usually more descriptive than the block casting number.)
  8. dasanii19
    Oct 11, 2006
    344
    NV
    ill be right back
  9. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    I have bought a few of those trucks over the years with "Corvette Motors":rolleyes: I always wonderd who all the idiots were yanking engines out of Vette's to put in pickup's:haha:
  10. u2slow
    May 9, 2001
    2,217
    BC Canada
    8 cylinders, in a vee configuration..... just like a Corvette. :rolleyes:
    Unless of course they mean the other 'Vette. :haha:
  11. dasanii19
    Oct 11, 2006
    344
    NV
    ok, there were small numbers 13L188923 then to the right there where bigger #/letters- VO116CKK but the 4th #/letter I was a little confused about, it didnt look like a #1, it looked like the #7 but with a line under it so I figured it was a #1. I was confused because the 4th didnt look like the 3rd "#1" The third looked like a #1
    Does that make sense? If not ill try to explain it better. Let me know
  12. u2slow
    May 9, 2001
    2,217
    BC Canada
    Here are the possibilities for the CKK
    4-98 (1.6L) 2BC 70 H.P.
    (VIN 9, OPT L17)
    Chevette 80 (:haha:)
    8-350 2BC 145 H.P.
    Chev Pass. 73
    Monte Carlo 73
    Nova 73
    Sprint (GMC) 73
    8-350 4BC 165 H.P.
    (VIN L, OPT LM1)
    Nova 76
    8-350 4BC 170 H.P.
    (VIN L, OPT LM1)
    Chevelle 77
    Monte Carlo 77
    8-350 4BC 175 H.P.
    Chevelle 72-73
    Sprint (GMC) 72
    8-350 4BC 200 H.P.
    Camaro 72
    Nova 72
  13. dasanii19
    Oct 11, 2006
    344
    NV
    So how would I find out exactly what it is?
    Are any of those motors decent for my K5?
  14. dasanii19
    Oct 11, 2006
    344
    NV
    They are all low HP, except maybe for the chevelle :confused:
  15. u2slow
    May 9, 2001
    2,217
    BC Canada
    Does it matter? Its a pretty average 70's 350. Stock, your Blazer would have had 145 or 160hp.
    Should be a 2-bolt main. 2BC vs. 4BC is pretty straightforward. Points or HEI? Orange or blue paint on the engine?
    Get the casting numbers form the head and block. www.mortec.com for reference. You should be able to nail it down a little closer.
  16. dasanii19
    Oct 11, 2006
    344
    NV
    Thanks for your help
  17. dasanii19
    Oct 11, 2006
    344
    NV
    So by the info I gave, is this enough to determine what headers will fit? any suggestions on what headers I should get? and where?
  18. After Ours
    After Ours 1/2 ton status
    May 23, 2005
    117
    Linden, New Jersey
    When you get headers, order them for the vehicle the 350 is in, not what it might have come out of. Hooker and headmen are 2 I have had luck with in the past.
    As far as the whole vette engine.... they used 4 bolt mains in some trucks and because they were used in vettes also I think people say it has a vette engine in it..It makes it sound fast...in the end a 350 is a 350, bore it, stroke it and love it.
  19. dasanii19
    Oct 11, 2006
    344
    NV
    Makes sense thank you.. Any suggestions on where to buy these headers at online?
