How to fill trans. case??
Discussion in 'The Garage' started by dallassnowman, Dec 14, 2003.
  1. dallassnowman
    dallassnowman 1/2 ton status
    Sep 14, 2003
    339
    Forney, Texas
    Ok new to all this!!
    How do you fill the trans case without spilling it everywhere??
    /forums/images/graemlins/k5.gif /forums/images/graemlins/1zhelp.gif
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Easisest is with a pump, or I bought a funnel at autozone with flex hose on it and just add a little at a time still kinda messy, but it works /forums/images/graemlins/thumb.gif
  3. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    Most autoparts stores have some really nifty pumps that screw on to oil jugs (Motor oil, ATF, rear-end grease, etc.)
  4. K5Jimmy
    K5Jimmy 1/2 ton status
    Sep 21, 2000
    1,141
    Lake Dardanelle/Logan Co, Ark
    I use a Sport Top water bottle.....fill it with tranny fluid, fits in the top hole, pop the top down when yer done usin' it...way cheep.....it also stores and travels well...
  5. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    on pickups you can use a piece of 3/8 hose on the end of a funnel..and run it between the bed and cab down into the tcase...
  6. dallassnowman
    Sep 14, 2003
    339
    Forney, Texas
    WOW, guess i had brain fart...I never would have thought of the sport bottle...thats great now to go fill er up!!!thanks
    by the way my wife thinks im crazy for postin questions on here! (i think shes jealous) /forums/images/graemlins/thinking.gif /forums/images/graemlins/rotfl.gif
  7. Confedneck
    Nov 1, 2002
    5,236
    just show her the $$ saved by doing it yerself and then see how crazy you are..LOL /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  8. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    or just show her how much ATF could have been all over the driveway if you dident post /forums/images/graemlins/thumb.gif
  9. dallassnowman
    Sep 14, 2003
    339
    Forney, Texas
    Yeah really...Dont remind me i still have to fix the leak
  10. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    I did the same thing but different /forums/images/graemlins/rotfl.gif
    If you use ATF heres what I did. I bought the blue funnel at Autozone with the flex tube However, I take the flex tube off the funnel and stick it right on the neck of the quart fluid bottle. While holding bottle upright, Insert tip on tube in xfr case. then lift the bottle up and lay it on its side against the bottom floor of the truck. It will flow in. You can also squeeze the bottle gently and force the fluid in a little faster. Works and little mess. /forums/images/graemlins/thumb.gif
  11. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    take the top of a gear oil bottle and screw it on the atf bottle. stick it in the hole and squeeze. /forums/images/graemlins/thumb.gif
  12. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Yup thats what I do /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  13. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    I went down to the hardware store got a small funnel and a see through hose, which makes the process a little easier. I got the hose the right size so it would screw into the hole. Poor slowly and when the ATF stops flowing take of the funnel, put it into the bottle and lower the hose to the funnel and pour the excess into the bottle, works damn slick /forums/images/graemlins/smile.gif
  14. louied
    louied Registered Member
    Mar 19, 2002
    84
    Philadelphia
    has anyone tried a fish tank pump , of any other type of electric pump?
  15. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    I don't think a fish tank pump would be able to move tranny fluid... lot thicker then water but you never know.
    I used an old piece of hose that i cleaned out and a mini funnel i had laying around. worked great... just takes a while to fill it all up cause you got to pour real slow.
