How to find a vacuum leak.......
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 84CUCV, Nov 4, 2004.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    I have a 1405 carb on my 80 p/u. It has been suggested to me that I have a vacuum/timing problem. When it get on the gas it shuts down. I thought it was a fuel problem. So what to look for so I can get her running right.
    Thanks for the help
    Mike
  2. alec78
    alec78 1/2 ton status
    Aug 5, 2002
    358
    Washington
    Have the engine running. Carefully and slowly spray it with carb cleaner. Listen to the engine. When it changes tone (speed), go back to where you just sprayed. Spray that area again, even more carefully and paying more attention. This will help you zero in on a leak. /forums/images/graemlins/thumb.gif
  3. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    Thanks i will give it a try. Mike
  4. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Or use a smoke machine.
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Propane works too. /forums/images/graemlins/thumb.gif
    I usually use carb spray or wd 40.
  6. crawford
    crawford 1/2 ton status
    Feb 13, 2004
    229
    Vancouver, WA
    Or use a peice of hose. Put one end up to your ear and check suspect areas with the other end for a hissing/sucking sound.
  7. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    Cool thanks more ideas. mike
