How to find out what tranny I have
Discussion in 'The Garage' started by la_blazer82, Aug 10, 2004.
  1. la_blazer82
    la_blazer82 1/2 ton status
    Apr 12, 2004
    148
    SoCal
    The identification tags on both the driver's door jamb, and the glove compartment have been removed by one of the prior owners. Where can I look to find out what tranny I have. What tranny do I want to have?
    BTW -- I have an 82 K5 Blazer (Silverado) 1/2 ton; 350 5.7L; I think I have the NP205 t-case.
  2. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    3 speed or 4 speed?
    if is it's an 3 speed it's an th350 and if it's an 4 speed it's an 700r4
  3. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    A square tranny oil pan also indentifies a TH350.
  4. la_blazer82
    Apr 12, 2004
    148
    SoCal
    3 speed or 4 speed?
    It's a four speed auto tranny w/Overdrive. Does this change it from being a 700r4?
    As for the t-case, I have to get under to take a look at the t-case, but the selector (in descending order) is 2Hi, 4Hi, Neutral, 4Lo.
  5. SF87K5
    SF87K5 1/2 ton status
    Oct 27, 2002
    1,105
    Stedman, North Carolina
    its a th700 and a np 208 tcase.
  6. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    one shaped like illinois (yeh thats what i think it is) is a th400, a square is 700r4, and a square w/ a corner cut off is a th350.
  7. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    you don't have a np205, you have a np208. Most half tons came with np205, until someone before you swapped it in.
    But you have a 208 from what you described.
  8. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    700r4 and np208 /forums/images/graemlins/waytogo.gif
  9. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    Hey, don't drag us folks from Illinois into this! /forums/images/graemlins/histerical.gif
    Actually, I have heard people refer to the 400 pan as resembling Texas.
  10. Nonesuch
    Nonesuch 1/2 ton status
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    Yeah Texas with the southern tip cut off and El Paso disappeared... Not like that would be a bad thing /forums/images/graemlins/histerical.gif
  11. smprider112
    smprider112 1/2 ton status
    May 1, 2004
    624
    Beaverton,Oregon
    From 81 and on 208's where standard...so someone didnt swap it in...its how it came from the factory /forums/images/graemlins/waytogo.gif
  12. la_blazer82
    Apr 12, 2004
    148
    SoCal
    Checked the factory specs link for 82s, and I have the optional TH700-R4 tranny, and the NP208 t-case (2.61:1 low range), which was standard. Thanks
