How to find out what tranny?
Discussion in 'The Garage' started by 84gmcjimmy, Mar 1, 2004.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Hey, Ive been reading some posts lately regarding tranny's. And sadly, I was puzzled because I dont no what tranny I have?? /forums/images/graemlins/confused.gif /forums/images/graemlins/dunno.gif I have a 1984 GMC Jimmy, 350 with a NP208 T-case... Thanks.
  2. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    If your pan is
    square=700R4 no modulator
    square with a 45* angle on 1 side=TH350 modulator on the side of tranny
    pan has an S-shape on one side=TH400 modulator near the tail housing
    Hope this helps. /forums/images/graemlins/thumb.gif
  3. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    /forums/images/graemlins/confused.gifhate to ask, but whats the pan you speak of?
  4. dhdescender
    dhdescender 1/2 ton status
    Aug 10, 2002
    628
    Qualicum Beach, British Columbia, Canada - Eh.
    Transmission Pan.
  5. Okiemuddog
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    The pan on the bottom of your tranny, do you have overdrive? It will have a D-with a circle and a regular D on your selctor on the dash, if you have overdrive it is a 700R4
  6. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    I'll check tomorrow when it's not dark. What happens if there is no D? Where is the D on my dash???
  7. Okiemuddog
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    you will have a D either way, it just matters if one has a circle around it or not. The indicator will be right above your steering column where it meets the dash. you will either have
    P-R-N-D-2-1
    or
    P-R-N-D with a circle-D-2-1
  8. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Oh I understand what you mean, but I forgot to mention I have manual, not automatic /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif
  9. Okiemuddog
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif, well you are out of my area then, maybe some of the manual guys can help you out, if it has four gears it is a SM465, if it has 3, the I cam't help you out, sorry /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif
  10. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Sorry I never mentioned that, but you helped me a bit anyways, my dad has a blazer same year, but automatic, so I'll find out what that has. Is there any advantages/disadvantages of having auto vs. manual? Im pretty sure I have a 465 then, unless the previous owners changed it. Manual guys: Should I stick with the 465, or whats a stronger manual tranny? Thanks for all the help /forums/images/graemlins/waytogo.gif
  11. Okiemuddog
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    Pros:
    the 465 is one tough tranny, and the preffered offroad manual tranny, better crawl ratio than auto and not chance of it burning up like a auto.
    Cons:
    having to change gears and work the clutch, clutch disc wear, other than that there are no cons I know of.
  12. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    So I should just stick with the one I have now then?
  13. Okiemuddog
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    if it was me I definetly would /forums/images/graemlins/thumb.gif
  14. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    You have been asking a lot of questions lately (which is fine /forums/images/graemlins/smile.gif) and I have gathered that you wan't a built 454 with 38's. Your best bet is to run your SM465 than try to swap over to an auto.
  15. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Yes you got it. Expect more questions in the future /forums/images/graemlins/doah.gif
