How to fix leaking plastic gas tank
Discussion in 'The Garage' started by bajaviking, Dec 10, 2003.
  1. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    A friend of mine has a Chevy Malibu 2001, he bumped the rear on something and now the tank is leaking from a small crack. A new tank is 616.00, does anybody know if the tank can be fixed. The tank is made of some kind of plastic material.
  2. Rob 85K5
    Rob 85K5 1/2 ton status GMOTM Winner
    1,487
    Pensacola, Florida
    Dry the tank and use an epoxy made to be exposed to fuel.
  3. guest
    guest Registered Member
    Aug 18, 2002
    41
    they make a small electric thing called a plasic welder, that will bond plastic together, ive used it on many things that hold gas,water,and many othere things, check it out, they should be able to get you one at any hardware store.
  4. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    You can rub a bar of soap into the crack to stop the gas leak temporarily. Then just clean the area and use some epoxy to fill the area if it is small. If it is big, you should probably pull the tank and do some sort of plastic weld.
  5. bajaviking
    Apr 10, 2002
    752
    Baja
    Thanks guys!
  6. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    marine tex, it will fix anything. it is made to repair cracked blocks, maifolds, and heads. i put it on my toyota a while ago and it is holding up better than the rest of the tank.
  7. bajaviking
    Apr 10, 2002
    752
    Baja
    Can you tell me where they sell Marine Tex.
  8. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    A product called "SealAll" works excellant with gas tanks.Comes in a yellow squeeze tube with red lettering.You can get it at just about any local hardware store.
  9. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Boat stores and occasionally gun shops as some use it to bed rifles. The plastic welder would be the more permanent cure. Harbor Freight sells them too.
