How to fix my braking power? What would you do?
Discussion in 'The Garage' started by FWP, Jun 17, 2006.
  1. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    1 ton axles, 4- 3/4 ton calipers on 42's. Stock M/C and Combo valve (75K5 Vacuum boost). I can't lock em up on pavement, even smashing the pedal with both feet (the pedal does not go to the floor BTW). After searching til my eyes went buggy, there's alot of opinions, but no answers for me.
    If you have my setup, or were in my shoes, what would you do, and why?
  2. tRustyK5
    Jul 23, 2000
    36,167
    1,365
    E-town baby!
    I run hydroboost with a C30 MC, stock combo/prop valve, D60 front brakes (bendix calipers) and D44 rear brakes. I can lock all 4 39.5's on dry pavement. IMO hydroboost is vastly superior to vac boost, and the larger bendix front calipers also probably help.
    Rene
  3. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    I have basically the same set-up as tRustyK5,stopping the 44's is no problem.
  4. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Understood. That being said, Hydroboost would not be in the cards for me. I need to have all the power steering power available to the steering box and ram.
  5. tRustyK5
    Jul 23, 2000
    36,167
    1,365
    E-town baby!
    I'm pretty sure Russ uses hydro boost and hydro assist steering...my box is tapped and ready.
    Rene
  6. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Yes he does, he'll tell you about braking vs. steering at the same time. Hence why I'm shying from HB
  7. jms
    jms 1/2 ton status Author
    Jan 24, 2001
    1,683
    Fred, would it be possible to run a second hydraulic pump - one for PS, one for HB? Using smog pump brackets and run the lines along the front x-member?
    Also, I seem to remember a post about using a vac booster/MC from a '79 1-ton as improvement for braking...
  8. Emmettology 101
    May 9, 2000
    8,126
    FL
    I think where your system may be lacking is the M/C and valve. Have you looked into swapping in a 1 ton master and do away with the stock combo valve? Run full power to the fronts(line straight from the master to the calipers) and then run a Wilwood style prop. valve for the rears..
    I think there was another post on here for another option to a 4wheel disc master cylinder...
    **EDIT** Link to master cylinder thread: LINK
  9. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    What business you got locking up tires, ennyhow...?! :dunno:
    I'd wheel it just the way it is.
    Marv
  10. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    I'd say swap your tires for some 38's:D j/k
    I don't know exactly why, but all I had was a stock brake system with disks in the back and I could lock all fours (with the 42's). (it was neat to see peoples faces when that happened) it was even pretty touchy, as in, very little pedal movement to even start braking.
    stock 83 booster, master, and proportion valve. (I swapped everything over to the new truck so I hope it is the same.
  11. crawlink5
    crawlink5 1/2 ton status
    Oct 9, 2003
    431
    Spring, TX
    Hydroboost. If I had to do it over I'd go hydro again. I never press more than 1/2" in stopping.
    Just put another power steering pump.
