How to fix steering column slop?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by OneInTheSun, Dec 29, 2000.
  1. OneInTheSun
    OneInTheSun 1/2 ton status
    160
    Pittsburgh, PA
    I know I've seen this subject before, but couldn't find it in the search. The front end and steering box are fine, but the steering wheel has about an inch of play in it up-down and side-to-side. I know there's something in the column that can be tightened - I'm just not sure what it is or where it's at. Thanks in advance.
    <font color=blue>Rob
    85 K5</font color=blue>
    [​IMG] 24 beers in a case, 24 hours in a day - Coincidence?
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Is it a tilt wheel? If so, there are some parts inside the column that can be replaced to make it as good as new. Can't remember what they call 'em but it's the hinge and the parts that lock it in place. Looks like a major PITA to replace 'em. [​IMG]
  3. dyeager535
    26,979
    There may be a write up online about this at some Monte Carlo web page. However, it is common with the trucks more than cars because people use the steering wheel to pull themselves into the vehicle. If you do that, break the habit : )
    You have to pull the column quite aways apart, if you are attempting this, you should go buy a $10 lock plate remover, because thats a major PITA by yourself without the tool. I can't remember how far you have to get into the column, but pulling the wheel, turn signal switch, and some other parts IS necessary. It isn't really hard, just quite a few pieces. There are three bolts in the column, and depending on year I assume, they may be torx. You'll see them inside the column when you get far enough, and you just have to tighten them.
    Dorian
    My K5 and Chev/Olds links: <A target="_blank" HREF=http://yeagerd.home.mindspring.com/index2.html>http://yeagerd.home.mindspring.com/index2.html</A>
  4. Here it is !! Step by Step !!
    Here is the infamous “GM tilt column loose problem” fix:
    Disconnect the Battery, Tilt the column to the full UP position, Pull the wheel
    Remove the locking plate, the large spring & the bearing cover (This comes off fine, but is a pain in the butt to get back on so I made a tool to put it back on)
    Disconnect the connectors for the turn signal switch, cruise and the "smart" switch
    Remove three screws that hold down the turn signal switch
    Gently pull the switch up and pull out of the housing folding down and hang by harness
    Remove the Ign Key buzzer switch and retainer clip
    There is either a screw on the right side holding in the IGN KEY LOCK or a slot in which you push a tab.
    Remove the screw or push the tab and remove the Ign Lock Cylinder.
    Most of us have been this far before into the tear-down.
    Next there are three or four torx head screws that hold the housing onto the tilt bowl, remove them.
    Return the turn signal switch back into the housing, do not put the screws back. This step is to give you some play in the wiring
    Gently pull up on the housing up and over the steering shaft. Tilting the shaft down will help but it puts the upper ball bearings in danger of popping out. The small cover for the tilt handle, the plastic push piece will all fall out
    There will now be a black bowl exposed. It has the bearings for the short shaft. The Hi Beam actuator rod will be coming through on the left side. There will also be a small rod through the top parallel with the floor. It is the sector shaft for the IGN Switch and has a small gear on the left.
    THIS IS IMPORTANT!! THIS IS THE PART THAT IS SPRUNG LOADED!!
    At the bottom is a small, about the size of a quarter, round silver plug with a square cutout in the center. This is the spring retainer. by tilting the column up most of the load has been removed from the spring. Take a #3 Phillips screw driver, put into the square hole. The object is not to go through this hole but to engage it. Push the plug down/in about 1/8 inch and turn counter-clockwise. There are two ears 180 degrees apart that retain the plug. REMEMBER IT IS SPRING LOADED!! Ease up until there is no load and pull out.
    The next step requires a small puller. I used small screws and vise-grips on one and a small crow bar on the other one !! They are in there pretty tight too !!
    There are two pins 180 degrees apart on the sides of the bowl. These are the tilt pivot pins and they need to be removed. Kent-Moore makes the special puller but I have seen other folks put a small screw in the hole and pull them out with Vise-grips. If the screws break you are hosed! The pins are harden and can't be drilled out if it gets screwed up.
    Once the pins are out put the tilt lever back in. Pull like you want to tilt the column. This releases the pawls from the retainer grooves.
    While holding them released, gently pull the bowl up towards you. The ball bearings are in danger of popping out again as they are disengaged from the races.
    You will notice that the upper shaft is connected to intermediate shaft by a white plastic ball socket. DO NOT BEND THIS TO 90 DEGREES OR IT WILL BECOME DISENGAGED!!
    Slide this to one side and two of four torx head screws will be exposed. I use a ¼” drive ¼” socket on a flex universal to gain access. This eliminates the danger of bending the tilt ball too much.
    If it's real loose tighten one from each side diagonally, That way the mechanism will seat and not bind. I recommend that you put locktite on them !!
    Going back together is just doing it in reverse with some extra steps.
    Reposition the tilt bowl on the shaft, pull back on the lever and slide on. Make sure the pawls engage the retaining grooves. The rods down to both the starter switch and the headlamp dimmer need to be lined up.
    Replace the tilt spring by depressing with a screw driver and turning
    To time the start switch the small snap ring retaining the sector gear, white or black plastic, and gear needs to be removed
    These will not be replaced until after the pivot pins are reset.
    Install these pins with a gasket hammer, SMALL! You may need to jiggle the bowl by actuating the lever disengaging the pawls
    Now time the ign rod rack with the gear and actuate a few times to make sure the Large cutout in the gear for the ACCESSORY position is timed. The rod has a tit that has to go into the racks crescent shaped area. This crescent shaped area allows the rod to be actauted from any tilt position when the key has been turned.
    Slide the turn signal housing down over the bowl, aligning the small tilt lever cover and headlight dimmer actuator. Small daps of grease will help hold this in position while trying to put it all together
    The rest is put together as taken apart.
    The Ign lock cyl goes in before the buzzer switch. The small tab on the lock cyl that actuates this switch needs to be held up in the close position. The IGN key needs to be out of the cyl for this to happen. Small dabs of grease will hold this up during assembly
    Another tip:
    Loosen the two nuts, maybe three that hold the column up to the dash frame. They are either 17mm or 15mm bolt heads. This will give you a little more play in the wiring.
    If you need any help, just e-mail me.
    [​IMG]<font color=red>BigBurb[​IMG]
    <font color=purple>IF YOU'RE SCARED, SAY YOU'RE SCARED !!
