How to gain a couple inches up front
Discussion in 'The Garage' started by Ben B., Aug 29, 2006.
  1. Ben B.
    Ben B. 1/2 ton status
    Sep 1, 2005
    352
    Central PA
    For this limited one-time offer, buy one container of Magnum triple X creme and get a second free!!
    Okay guys, in all seriousness, :p:
    I've got a 3" all leaf spring lift on my K5 that rides like a peach that I'm thinking about putting on my stock K10.
    The problem is, I'm gonna be running 35's. Now out back I can just block it or add the 2.5 shackle flip. But the tough part...How can I gain a couple inches up front?
    The 35's rubbed like crazy with this lift on the K5, so they'll rub on the K10 too.
    I can add a BL, but don't want to at all. Just need a couple inches up front. 2-3 extra inches would be fantastic.
    Thinking zero rate and maybe some extended shackles, or just save up for 4" TC leaf springs. Suggestions welcome.
  2. jamber2541
    jamber2541 1/2 ton status
    Apr 10, 2006
    424
    e.p. texas
    longer shackles and some 1" zero rate add a leafs should get you a couple of inches, look in the vedor forum
  3. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    a pair of zero rates in the front, and move the axle forward 1 1/2, and i'll bet you're set. i dont think you can do that with stock style steering though.
  4. Ben B.
    Sep 1, 2005
    352
    Central PA
    I don't wanna mess w/ the steering. Ugh..I guess I'll just have to find some 4" leafs. Even crappy ones with a few springs removed will ride decent won't they?
  5. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    go with zero rate up front, but don't use them to move the axle, just use them for lift since you still have push/pull steering right now. This will give you 4" up front. You can also do zero rates out back, and you'll have 4" out back.
    top that off with a 1" body lift, and you'll be clearing 35's just fine.. you can always :hack: too :wink1:
  6. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    bushwacker cut out flares and a zero-rate. You need the flares in Pa anyways to keep johnny law off your tail.
  7. Ben B.
    Sep 1, 2005
    352
    Central PA
    Truck's just had new fenders and repainted...don't think I wanna hack it. Damnit. Fender flares will cost a good deal more from 4" leaf springs anyhow.
  8. gmc4cw
    Jul 19, 2006
    3,907
    west chester, Pa
    flares cost less then the fine. In Pa its $163 per tire. and they measure from the sidewall now.
  9. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    For a 4" spring I highly re-recommend this Spring.
  10. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,486
    1,191
    So Cal.
    penis pump :D
    you started it :haha:
