how to get 14ff hubs off drums?
Discussion in 'The Garage' started by muddybuddy, Jul 20, 2005.
  1. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    hey guys, this is the only thing thats stopping me from doing my disc conversion. how do i get the 14ff hubs off the drums? do i just have to beat it? i have the hub/drum off the axle. also, how do i get the 8 lug studs out?
    thanks
  2. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    press/beat/hammer the studs out, the drum with come off
  3. scrappy88
    scrappy88 1/2 ton status
    Mar 14, 2003
    314
    Loveland, CO
    Press them out if you can. Beating on them usually bends and messes up the studs and you can't re-use them for the disc conversion. They are expensive to replace, ask me how I know. :doah:
  4. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    so do i jus hit the hub til it separates from the drum? im considering dually studs so that part isnt that important, i jus wanna get the hubs off since i need to reuse them.
  5. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Have you removed the lug studs? Mine fell apart after the studs were removed.
  6. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    WAH :confused:
    so your doing a disc conversion on a 14ff? right? just re-use the studs you have. with the studs facing up beat then down into the drum, this will sperate the hub and the drum. BUT do not beat on the with a hammer directly, you will damage the studs. you need a brass drift or a brass hammer. using a brass drift place it between the stud and the hammer and beat on the drift. Brass is softer than steel and will not damage the studs.
  7. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i read somewhere that the regualr studs might not be long enough, and that the dually studs would allow for more options with rims??? maybe i misread?
  8. divorced
    Jul 20, 2004
    5,115
    There was plenty of thread left on mine after a disc brake swap. The disk isn't much thicker than the drum, so not much stud length is lost, if any at all.
  9. avgas
    avgas 1/2 ton status
    Jun 5, 2003
    179
    Renton, WA
    I beat mine out, but to prevent bunged up threads I screwed the lugnuts on until they were nearly flush with the end of the bolt. Then I beat on the lugnuts.
  10. beater74
    May 29, 2001
    1,749
    atlanta
    yeh yer studs "should" be just fine. i'd try them first
  11. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    alright and then when i need to put them on the disc, what do i do to press them in? what kind of tool do i need? or should i just go somewhere and have them do it?
  12. divorced
    Jul 20, 2004
    5,115
    I hammered mine in from behind. Lay the face of the hub down, set the rotor on it, install studs, hammer away. I used a piece of angle iron as a punch so I wouldn't hit the rotor with my hammer. You can tell when they are fully seated because the sound of your hits will change.
    Any shop that has a hydraulic press can press them in also.
  13. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    thanks alot.
    i love this club, im glad i became a full member. the info i have learned on here has really saved me a ton of money. being a teenager and learning all this stuff and being able to do it myself is sweet.
  14. avgas
    Jun 5, 2003
    179
    Renton, WA
    What I di to press mine in was tap the studs in as much as you can with a hammer then to get the fit really tight flip the whole thing over install all the lug nuts(must be the open type) with the flat side toward the rotor. Then start going in a roughly star shaped pattern with an impact wrench hitting each nut with just a couple of impact "hits" each in rapid succession until everything is flush and tight. Worked great for me! make sense?
    -jake
  15. Kingston
    Kingston Registered Member
    Aug 1, 2001
    7
    Alberta, Canada
    Use a good punch and a hammer. Works great!!
  16. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    14 bolt disk breaks
    just beat them out with a nice hammer carefully and reuse the studs,they will be fine. I did it twice cause 1 of my hubs was leaking and had to change it again so i beat my studs out twice and the nuts went on smooth
  17. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    See now this is good to hear, a younger guy, listing and asking questions instead of spewing off like he know's every answer to every question in the world, like some people on here, Ahem, not mentioning any names :D
    Good on ya man!!
    You will find by listining to the mistakes of other's you will save yourself alot of time/money/grief!!!!
