How to get a pinion nut loosened: the last resort way
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Sidepipes, Apr 27, 2003.
  1. Sidepipes
    Sidepipes 1/2 ton status
    Nov 9, 2002
    139
    St. Thomas, Ontario, Canada
    Just thought I'd share my weekends experience in case it might help someone out.... most of the experienced guys probably know this anyways.
    After a mud run on Easter Friday my rear end developed a bad front pinion seal leak so I figured I better fix it before I starved the front bearing of oil.
    I tried to undo the pinion nut the proper way with a torque wrench( so you know what to torque it back up to) with no luck.... 150 ft-lbs of torque and beyond and no luck.
    Next stop, a 36" breaker bar.... no luck.... a 36" breaker bar with a length of pipe.... still no luck.
    So I try what I really don't want to try.... Iput the breaker bar up against the P.S. leaf spring, tie it to the spring with a bungee cord( only to keep the bar in place while I move it forward), lock the hubs, put it in 4-high and move it try and move it forward.
    It finally broke free on the 4th try. Really scary because I could have broke the pinion, the threads on the piinion or the pinion nut..... but it was a last resort to get the nut off.
    Alls well now, the leak is gone..... not really sure if I put enough torque on the nut but everything seems alright now.
  2. tori89k5
    tori89k5 1/2 ton status
    Apr 12, 2001
    946
    Pismo Beach, California
    Next time you might try an impact gun. Even if you had to drive to a near by shop, have them zip it loose, then put it back on by hand till you drove home...
    But a good fix at any rate. /forums/images/graemlins/thumb.gif glad it worked out for the best.
  3. Sidepipes
    Nov 9, 2002
    139
    Top of the line Mac Tools impact wouldn't get it off. I 've seen this gun take off a lot of stuff and it wouldn't take this off.
  4. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Someone used Loctight ?
    Some Loctight will lossen up with Heat.
  5. ramjet gmc
    ramjet gmc CK5 Staff Staff Member Moderator GMOTM Winner
    Dec 19, 2001
    3,370
    Milltown NJ 08850 NJ sucks
    i 2nd that
    i tryed my thunder gun on mine and no luck but a pipe will do it every time /forums/images/graemlins/rolleyes.gif
  6. 85burbanator
    85burbanator 1/2 ton status
    Feb 10, 2003
    577
    lake orion, mi
    has anybody had there impact explode on them? mine did today when i was removing the axel shafts from my 14bff so i could remove the stupid gov lock carrier. scared the hellouta me. but my dad fixed it and it worked again. i think its time for a new one.
  7. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    MAC, no way, Ingersoll-Rand!!
  8. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    My Rockwell 1/2" drive doesn't usually fail to get something off, but if it does, I got the 3/4" to get it off. That 3/4" will break your arms if you're not careful.
