How to get drums off 14bff??
Discussion in 'The Garage' started by 85mudblazin, Aug 14, 2004.
  1. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I need to take the drums off to check out the breakes and I was wondering how to get the drumm off.
    -Chris
  2. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    take all the bolts off and wack it with the side of a hammer to losen it up. then it should come right off.
    oh make sure u dont wack the edge of the drum. hit it in the center
  3. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    After you get the tire and wheel removed you will need to remove the bolts holding the axle in, get them out and slide the axle shaft out. Then unscrew the axle nut and remove the lock washer and spacer, remove inner nut, remove outer bearing.
    At this point the drum may or may not come off. If it doesn't you will need a small screw driver to back off the brakes on the self adjusters. There will be a slot in the backing plate and there will be a small ring gear looking thing and you will need to turn it with the flat head. This takes a while but when you get the adjuster backed off the shoes should allow the drum to come off. /forums/images/graemlins/thumb.gif
  4. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    14 bolt full float /forums/images/graemlins/deal.gif /forums/images/graemlins/deal.gif /forums/images/graemlins/deal.gif
  5. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    I was a little /forums/images/graemlins/screwy.gif for a minute when he said that.
    I tried taking all the bolts out of the hub but I have the 14bff on jackstands in the garage and the wheel would just turn, then I tried a breaker bar, guess this gives me more of a excuse to get a compressor /forums/images/graemlins/thumb.gif
  6. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    [/ QUOTE ]THose axle bolts get really tight. Even my 1/2" drive impact won't take them out at first. I have to break them all loose with the breaker bar first.
  7. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Use a tie down strap against one of the notches in the hub and strapped to a spring perch or something. Start turning the bolts until the strap becomes taught now you can lean on it without the hub and drum turning. Just careful you don't roll it off the stands onto your toes.
  8. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    I had a chain lyin by my 14FF so I hooked it to a shock mount then put it so the pinion couldnt turn then wrapped the other end up somewhere...
