How to get poly bushings out of spring eye's?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chevyfumes, Apr 6, 2002.
  1. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    How to get poly bushings out of spring eye\'s?
    Just got new springs and was wanting to put greasable bushings in , do I have to drill the poly bushings like the rubber bushings or can I just drive them out?
  2. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Re: How to get poly bushings out of spring eye\'s?
    You should be able to drive 'em out without a problem...I would get a deep socket and drive out the metal sleeve the you should be able to use a drift or something to get the busings out...or you could try putting the busing in a vise (the 1/2" or so that is to the side of the sprring-eye) and use a rubber maller an whack the spring away so you leave the bushing in the vise...
    Chris
  3. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    On the poly bushings all I did was grab the end with a pair of vise grips and twisted them out. I tried the "drill" way and all it did was break the bit. When I did my ORD shackles I did both sides in under an hour. No heat, no fancy tool, and no drill(after i broke it on the first attempt) I used a hammer, a punch(to drive the metal sleeve out, with no problems) and a pair of vise grips.
  4. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Torch'em... When they turn black take a hammer and pound them out. Really fast,and you get to use fire /forums/images/icons/smile.gif
