How to get shackle bushings out?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by txbartman, Oct 25, 2001.
  1. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    I just got my ORD HD greaseable shackles in yesterday. I plan to start installling them soon. How do I get the existing rubber bushings out?
    When I replaced my bushings in my swaybar, it was a pain in the butt. I drilled numerous holes and beat the crap out of it with my BFH until it finally came out. Is there a better method for the shackle ones and the ones in the eye of the springs?
    I also don't have a torch so I can't use the heat method. Or, is that a better way and justification for getting one of those small propane torches? Would it even work?
    HELP!!!
    Brian
    Check out <a target="_blank" href=http://tx85gmcguy.alloffroad.com>My Jimmy</a> with all her projects!
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    About the only other way that I know of would be to use a press and push them bushings out.
    Other than that idea, what you have done is how I get them out. The torch is my "last resort", as I do the drilling first. [​IMG]
    I'm not picking my nose...I'm just pointing at my brain!! [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
  3. tRustyK5
    Jul 23, 2000
    36,166
    1,363
    E-town baby!
    The little propane torch would do it...all you need is enough to get the rubber burning. Let it burn for a little bit and it should fall out. Keep an extinguisher handy though![​IMG]
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  4. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    drill holes and if you have the leaf out far away from under your vehicle, dose the end in gas and light a match to it. this is highly NOT recommended method, but it has a similar effect to the torch. or you can just get a propane torch. you will see black smoke, try not to breath it in at all costs. very toxic stuff.
    ARQ.
    offroad baja!!!
    72 4x4 CST Blazer
    71 4x4 CST Blazer
    <a target="_blank" href=http://coloradok5.com/gallery/ArqDennis>My Pics</a>
  5. bigjbear
    Feb 18, 2000
    13,964
    447
    Marietta GA
    FIRE! This is the absolute best way to remove rubber bushings. All you need is one of those cheap plumbers torches.
    Jim '80 GMC & '73 Blazer
    Body by Tellico
    <a target="_blank" href=http://www.tellicok5.rockcrawler.com>www.tellicok5.rockcrawler.com</a>
  6. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    I had great luck with a 20 ton press. After your gear installs and doing bushings the BFH way, it make you appreciate hydraulic power presses (good investment, if you don't already own one). A 12 ton with do fine too, it's just that I have access to a 20 ton so I use it. One note, you still need to remove the inner metal sleeve. A BFH and chisel will do, but a pneumatic chisel with a muffler splitting attachment makes the job a cake walk (just loud).
    See my rig at <a target="_blank" href=http://coloradok5.com/gallery/Leadfoot>http://coloradok5.com/gallery/Leadfoot</a>
