How to get studs out of water pump
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90K5, Sep 14, 2002.
  1. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Just changed my water pump, but its got four studs that the fan bolts to...how can I get these out? They are threaded studd and I don't really have any way to tur nthem without messing up the threads...Anyone just used bolts?
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    On my 75, my fan is BOLTED to the water pump with bolts.
  3. 4x4k20
    4x4k20 1/2 ton status
    Mar 17, 2001
    1,699
    williamson ga.30292
    double nut it with a washer between the 2 nuts tighten them together and then put your wrench on the bottom one and screw it out
  4. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    That is what I do, too.(double nut) But if you cant get them out new studs are cheap, look in your parts store's "Help" section.
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Yep, you can either double-nut 'em or use a stud wrench. /forums/images/icons/cool.gif
  6. SWAMPRNR
    SWAMPRNR 1/2 ton status
    Apr 7, 2001
    296
    Temple Texas
    I bought new ones from auto zone for a couple of dollars when i couldnt get my old ones out.
  7. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Thanks, just double nutted them and they came out...
