How to get the top off??
Discussion in 'The Garage' started by 85mudblazin, May 20, 2004.
  1. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Since it is getting close to summer time I am thinking about taking my top off, what are some of the methods yall use to get it off? /forums/images/graemlins/k5.gif----> /forums/images/graemlins/truck.gif /forums/images/graemlins/thumb.gif
  2. Storm Trooper
    Nov 24, 2000
    4,640
    Don't worry, it shouldn't be hard. Unbolt all the top bolts and ones on the cab. In the back of the bed is a bolt on each side the come up from the bottom. Unplug the wires, go to the beer store and buy a bunch of beer. Invite your friends over for a beer (4 people, 24 beers min. recommended). Warning, only have one or two beers before removing the top (on the truck! not you). After carefully setting top down, continue to drink all available beers and your done /forums/images/graemlins/rotfl.gif.
    If you run into any trouble removing the top, send a non-drunk friend or wife to the beer store for another 12 pack while you figure out what bolts you missed.
  3. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Mine has 1/2" bolts in it. I get a ratchet undo the bolts stand in the back and pop ot off the pins on the bed rails. Then a buddy and I will each lift one side and place on ground. Peace of freakin cake /forums/images/graemlins/waytogo.gif Oh yea when you put it back on I only put 2 bolts back in on the sides but all back in where it meets with the cab. Makes taking it off next time a little easier.
  4. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Is there any way to do it buy yourself, say if all your friends are gone or just to lazy to help?
  5. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
  6. unick
    unick 1/2 ton status
    Aug 16, 2003
    4,286
    San Diego Comufornia
    My brother takes his off by himself and hes little. Remove the bolts and stand up underneath it whith ur back on the roof. Then push it back to where itll almost fall off and then get out and pull it off SLOWLY till you can set part of it on the ground and make sure it doesnt fall off or your screwed. If I were you id find a friend cause that thing weighs ALOT!
    nick
  7. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Tomorrow is my last day of school and we get early out so I will take the top off tomorrow and ill let yall know how it went. /forums/images/graemlins/thumb.gif
  8. lifethroughdeath
    lifethroughdeath 1/2 ton status
    Jan 26, 2003
    300
    New Bedford, MA
    i know someone mentioned it allready but don't forget the 2 hidden bolts, on the inside of the rear panels. There is one on each side at the back. The first time i took my top off i forgot those two damn bolts, and nearly lost my mind /forums/images/graemlins/yikes.gif I was pushing and lifting to no avail, man was i pissed /forums/images/graemlins/angryfire.gif Then i looked behind the panels and there they were /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gifBoy did i feel stupid! Good luck
    Nate /forums/images/graemlins/k5.gif
  9. duece21
    duece21 1/2 ton status
    Jan 18, 2004
    501
    Aurora, CO
    I just took mine off and it went rather smooth. I followed the write up about using pully's and rope, but w/ anyone to help you lift the other side it's useless. So I have come up w/ a winch system using the same idea. Some bearings from boat house winch system,2" conduit, trailer hand crank winch, and cable. You get the idea /forums/images/graemlins/waytogo.gif Then all I have to do id hook up some clips and crank away.
