How to get yoke out of differential
Discussion in 'The Garage' started by K5Steve, Sep 11, 2005.
  1. K5Steve
    K5Steve 1/2 ton status
    Aug 10, 2005
    288
    Carson city, nv.
    What size is the nut holding it on?Does it press on?I just found that the nut holding mine on was a little loose.It turned with a cresent wrench.
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    What axle ?
    I have used a 1 1/4 on 10 bolts , 1 1/8 on 12 bolts . Never done a 14 bolt myself .
    You are supposed to do it a certain way , to preload the bearings properly .
    Do a search been covered .
    Personally , mine was tightened on as tight as we could with a breaker bar when I swapped my 12 bolts from truck to truck , and all is well for thousands of miles .
  3. K5Steve
    Aug 10, 2005
    288
    Carson city, nv.
    It is a 10 bolt,sorry.I wanted to see if it was tight so I used a cresent wrench just to see if it would move and it did with minimal strength.Will the yoke slide off with the nut removed or is there a specail way to get it off.
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Sometimes the yoke will just slide off, but many times you'll need some type of puller to get it to turn loose of the pinion shaft.
  5. koldsimer
    koldsimer 1/2 ton status GMOTM Winner
    Jan 10, 2005
    1,480
    texas
    Whack it.
  6. Geargrinder
    Geargrinder 1/2 ton status
    Jan 21, 2005
    258
    Medford Oregon
    Yup, 1 1/4" nut (nyloc, poly lock, what ever U wana call it) and 2 or 3 good whacks IF it is stuck, if not it will just slide off. I just did this to 2 10B's last week. U wamt the pinion to turn smoothly, but not real eazy :crazy: It's hard to describe, just gota know what U are feeling for.
  7. K5Steve
    Aug 10, 2005
    288
    Carson city, nv.
    Thanks,I'm going to replace the yoke today.It's worn down so now my u joint slides around,I just replaced the straps.
  8. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Sounds more like it's broken. There are supposed to be little tabs on each side that prevent the u-joint from sliding side-to-side. :eek1:
  9. K5Steve
    Aug 10, 2005
    288
    Carson city, nv.
    There are,I think they're worn down because the u joint slide back and forth and hits them.The spicer that was in it did it and the new joint is doing it too.
