How to hook up e-brake on caddy calipers??
Discussion in 'The Garage' started by 85mudblazin, Aug 13, 2004.
  1. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I am thinking about swapping my 14bff drums to disk and I was wondering how you hook up the e-brake to the caddy caliper??
    -Chris
  2. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
  3. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    That's kind of the setup I was looking to fab up. Looks like your caliper bracket is mounted clocked almost straight back from the axle. Mine sits higher up and the issue I've struggled with is keeping the cable housing close to the tube and somewhat straight so it doesn't droop down without making the cable cut sharply upwards to meet the lever. I'm afraid if I make the angle too sharp coming out of the end of the cable housing it will rub and eventually wear the cable through. Here is how mine looks before I put the brake lines on:
  4. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Here is another one I had but the background looks awfully familiar /forums/images/graemlins/thinking.gif Perhaps one of your first incarnations?
    I'm wondering if maybe I should've clocked my bracket farther back.
